heater hose for gsr swap?
Old Aug 5, 2003 | 12:56 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default heater hose for gsr swap?
i was just wondering what heater hose you guys are all using for your gsr swaps, mine gets a kink into it, the hose that goes to the intake manifold is the one that kinks, waht hose should i use, or should i just put a piece of something in there and put an extension on it? or is there a certain hose?
Old Aug 5, 2003 | 01:01 PM
jaysonx's Avatar
Default Re: heater hose for gsr swap? (coptzer)
This is real easy, go to pep boys or the like and get yourself some heater hose (comes in a big bag). Pick up some hose clamps as well and go to town.
Old Aug 5, 2003 | 05:33 PM
i tried and all i ended up doing was getting the hookup to the heater hose to the car bent and the hose wont come off, is there a piece or something i can stick inside to add another piece of pipe to to lenghten it?
also on another note, i installed gsr radiator and i cant get the fan to work, i hard wired it to make sure it works and then i plugged it in and it wont kick on, its making the car over heat?? what could be my problem, i made sure it was full of coolant
Old Aug 5, 2003 | 05:36 PM
SpeedDreamz.com's Avatar
Default Re: (coptzer)
Sounds like the sending unit or relay. Possibly a connection on each.
HndaOwner
Mar 8, 2016 04:14 PM
Econo'Box
Oct 25, 2007 09:02 PM
coot_er
May 14, 2004 01:52 PM
daver
Aug 20, 2003 09:37 AM
b16pwrcrx
Jul 10, 2003 06:30 PM
