best way to remove seized bolt?
Old Aug 5, 2003 | 12:47 PM
igo4bmx's Avatar
Default best way to remove seized bolt?
I have the three bolts on my cat stuck on... any good products to eat away at the bolts? or should i use a torch.
Old Aug 5, 2003 | 12:48 PM
Kamin's Avatar
Default Re: best way to remove seized bolt? (igo4bmx)
Impact gun
if that dosent work
Impact gun + blowtorch
if that dosent work
Dremel to cut them off.
Old Aug 5, 2003 | 01:08 PM
civic-4-ges's Avatar
Default Re: best way to remove seized bolt? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">Dremel to cut them off.</TD></TR></TABLE>
Old Aug 5, 2003 | 01:26 PM
Mr. Choi's Avatar
New User
try some penatrating oil "liquid wrench" spray some on the bolts tap it with a hammer
a bit, let it sit, tap again, then remove bolts.
Old Jul 8, 2007 | 08:03 AM
The Epidemic's Avatar
Default Re: best way to remove seized bolt? (Mr. Choi)
any thing else&gt;
Old Jul 8, 2007 | 09:50 AM
92ehatch's Avatar
Default Re: best way to remove seized bolt? (The Epidemic)
i would just cut the nut off and replace the bolts.
simple, quick, effective, cheap
Old Jul 8, 2007 | 12:03 PM
Papi4baby's Avatar
http://www.amazon.com/Blaster-...JM8GS
Most places carry it.
Old Jul 8, 2007 | 12:07 PM
teamworxek9's Avatar
torch them off and replace with nut and bolt ftw.
Old Jul 8, 2007 | 12:10 PM
ke98248's Avatar
Default Re: (teamworxek9)
cut it off with a dremel or cutting wheel attachment on a grinder. Get replacement bolts/nuts if you didn't get any with the new cat-back system.
cedrichawkda6
Suspension & Brakes
Aug 3, 2010 09:30 AM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
david90
Dec 2, 2003 06:42 AM
Nice_Dc2r
Oct 23, 2003 10:41 AM
syndicate43
Nov 25, 2002 05:49 PM
