OK im putting the stock motor back in my car, lemme make sure i got everything....
Old Aug 5, 2003 | 11:26 AM
slowdx's Avatar
Default OK im putting the stock motor back in my car, lemme make sure i got everything....
Ok i have a 95 dx coupe witha 95 gsr swap but im pulling out the gsr and i just bought a dx longblock from spoonsportsjunkie here on h-t.
I want to make sure i have everything......
OK so the clutch is installed already right? Is all i have to do is bolt up the tranny right?
Here is the tranny, little dirty and rusty, just been sittin for a few months...ill clena it up, i got this free froma friend it didnt grind and ran finei already took the remnants of the clutch out...Im confused i rebuilt my motor but i dont know ish about trannies or clutches....Do i need to do anything ecxept bolt it on..?
Whats missing off of this? i remember takin soemthing off of it but i forgot what, sorry guys im retarded....
Also im not sure if i used my stock engine harness or the gsr, im guessing the gsr....(i got my swap done by a friend before i knew anything, well i still dont)
Can i use the gsr harness when i put the dx in or do i buy a dx one?
Also can i use the mounts that are in the car right now that are holdig the gsr motor in to put the dx in or what ones will i have to get that are diff....
HELP ME OUT GUYS IM STARTING MY SENIOR YEAR THURSDAY AND I NEED MY CAR AT LEAST BY NEXT MONDAY
Old Aug 5, 2003 | 11:32 AM
Hankish's Avatar
Default Re: OK im putting the stock motor back in my car, lemme make sure i got everything.... (slowdx)
it looks like the clutch is still on the motor, and still on the tranny. I would pull the one off of the tranny (it is just chillin on the input shaft, looks like,) and use the one that is still bolted to the long block.
The starter goes in that hole on the tranny.
Can I gave your GSR? whan you take it out?
Hank
Old Aug 5, 2003 | 11:34 AM
slowdx's Avatar
Default Re: OK im putting the stock motor back in my car, lemme make sure i got everything.... (Hankish)
You can buy the head...im keepint he block lol
Yea i went back and edited and said i took out the clutch outta the tranny and cleaned it up some so theres no rust...so all i would have ot do is bolt the tranny on? no aligning or anything?
Old Aug 5, 2003 | 01:00 PM
slowdx's Avatar
Also, can i use a 95 civic ex engine harness? or do i HAVE to use a dx harness.
Old Aug 5, 2003 | 04:41 PM
slowdx's Avatar
ummm yeah and stuff
Old Aug 5, 2003 | 10:08 PM
slowdx's Avatar
bump
Old Aug 6, 2003 | 09:22 AM
slowdx's Avatar
u guys suck
Old Aug 6, 2003 | 03:04 PM
slowdx's Avatar
I think the harness will work, it seems ot siton everything.... but what about the mount situation? What mount will i need?
Old Aug 6, 2003 | 03:20 PM
Blaze45's Avatar
Brrraaaap!
Your gonna need to use the stock D series mounts... You cant use the B series one. How much you want for the VTEC head?
Blaze
Old Aug 6, 2003 | 05:32 PM
slowdx's Avatar
Default Re: OK im putting the stock motor back in my car, lemme make sure i got everything.... (Blaze45)
Dont you use a couple of the stock mount when doing this swap, i cant remember....
Im not sure, Pm me and ill give u a description and then you can make an offer.
Old Aug 6, 2003 | 06:15 PM
quik1's Avatar
Only the upper and lower tranny mount.
Old Aug 7, 2003 | 12:59 PM
slowdx's Avatar
Default Re: OK im putting the stock motor back in my car, lemme make sure i got everything.... (quik1)
So i need ot buy the upper and lower tranny mounts.....from 92-95 civic with d series motor?
Old Aug 7, 2003 | 01:56 PM
slowdx's Avatar
http://www.hondaautomotivepart...81%29
so number 11 and 14? which ones is it guys? i might be going to pick it up tonight so someone reply quick
Old Aug 7, 2003 | 05:52 PM
quik1's Avatar
The only ones you can keep are the upper and lower tranny mounts number 5 and 14. Sorry if that sounded like it was the other way.
Old Aug 7, 2003 | 07:13 PM
slowdx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">The only ones you can keep are the upper and lower tranny mounts number 5 and 14. Sorry if that sounded like it was the other way.</TD></TR></TABLE>
Alright thanks, I picked up all three just in case....
Megaton22
Apr 23, 2013 09:24 PM
REX90stock
13
Jan 17, 2008 06:40 PM
downest
Apr 25, 2006 07:36 PM
sinister357
Sep 19, 2004 01:55 AM
Iceycrx
Oct 18, 2002 04:34 PM
