JDM D15b vtec parts? Please help.
Old Aug 5, 2003 | 11:10 AM
1990hondaHF's Avatar
Default JDM D15b vtec parts? Please help.
I need to know the part numbers for these from Autozone, Discount Auto Parts, Pep Boys, or someplace like that. This is for a (grey plug..OBD-1)JDM D15b vtec engine and tranny.
spark plugs
spark plug wires
water pump
timing belt
clutch assembly
flywheel
Thanks!
Old Aug 5, 2003 | 11:56 AM
dantastic's Avatar
Default Re: JDM D15b vtec parts? Please help. (1990hondaHF)
im pretty sure the clutch, flywheel, spark plugs and wires would all be d16z6 spec. i could only guess the timing belt and water pump are the same. you could always pull off the timing belt and water pump and compare them to d16z6 parts at the store
Old Aug 6, 2003 | 05:20 AM
Default Re: JDM D15b vtec parts? Please help. (dantastic)
anyone confirm please?
Old Aug 6, 2003 | 05:32 AM
nate_d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the clutch, flywheel, spark plugs and wires would all be d16z6 spec. i could only guess the timing belt and water pump are the same. you could always pull off the timing belt and water pump and compare them to d16z6 parts at the store</TD></TR></TABLE> <U></U>
confirmed
hondur
Jan 16, 2017 09:58 AM
SharkEg
Apr 17, 2012 04:08 PM
ArithMEHtik
Aug 15, 2011 10:58 AM
mnneon
Jul 17, 2005 07:08 AM
alleyezonme
Apr 8, 2004 08:26 PM
