motor problem with my eg
everyonce and awhile when i start my car it starts and then 3 seconds later it sputters out and then wont start again. I have no idea what this could be (distributor?? maybe) tahts my only guess. And what is more wierd is that i can come back an hour or so later and try and start it and it starts fine.
I need help
I need help
sounds like your main relay
when you see the idle start dropping down, do you press the clutch in all the way or even try and rev it up and will not do anything?
i had a similar problem and changed my relay, took care of everything
Sounds like your main fuel relay....
Try these for information:
http://autorepair.about.com/li...1.htm
http://www.markl.f9.co.uk/howt...y.htm
collkid
13
Sep 16, 2015 09:10 PM
90jdmcrxdude
Aug 5, 2006 07:34 AM
