Cleaning Wilwood calipers!
Old Aug 5, 2003 | 05:59 AM
b16supertuner's Avatar
Default Cleaning Wilwood calipers!
Hey, My wilwood calipers have about 12k on them, and mad brake dust baked/caked on, i was wondering if it would be safe to soak them in parts washer solvent for a while, then clean that off with brake parts cleaner and a brush. i get worried because the pistons are dirty and i know they dont have dust seals. should i contact wilwood for a rebuild?
Thanks.
Old Aug 5, 2003 | 10:15 AM
JDMHN8's Avatar
Default Re: Cleaning Wilwood calipers! (b16supertuner)
If they are that bad, then a rebuild is a good idea. They do not have dust seals, so keeping them really clean is imperative. I rotate my tires every two weeks and wash my wheels and Wilwood calipers once a month. 5,ooo miles and no problems.
You'll need the caliper and body seals for the rebuild and perhaps some new pistons if the old ones are scored. It shouldn't cost more than $30 for the seals. I'm not sure on the bore size for the seals, but part #130-2658 is for a 1.38" bore and #130-2655 is for a 1.75" bore. Body seals are #210-2582, 4 pk. of bleeders is #220-0627 and a 10 pk. of pad cotter pins is #180-0056.
Good luck! Check the Wilwood site for rebuild instructions.
This place has all the parts you need:
http://www.northwestracing.com...wood/
Old Aug 5, 2003 | 12:32 PM
Default Re: Cleaning Wilwood calipers! (JDMDA9)
i called wilwood and they told me that all i would need to replace were the main seals behind the pistons, (bore seal i am guessing) so now i need to determine what bore size i have, then he told me that he had no instructions because it was a easy rebuild. i'll attempt this and let you know how it goes. Thanks!
druhoo
Suspension & Brakes
11
Oct 4, 2012 11:04 PM
thrty8street
May 31, 2010 07:10 PM
Cuppycake
Jul 14, 2006 09:01 AM
blkgsr03
Feb 9, 2005 07:56 PM
OEMaccord
Feb 2, 2003 06:21 PM
