it finally died
Old Aug 5, 2003 | 02:29 AM
.Noah Fecks's Avatar
Default it finally died
ok so i got this hunk of **** car and it finally died on me.
ill be driving down the street and everything is cool. then bam the idle goes really low and it cuts out. i think its the fuel pump. sucks for me i just filler up yesterday. i get to drop that sucker later today. let me tell you how excited i am. what kind of test can i run to make sure that its the fuel pump?
Old Aug 5, 2003 | 03:27 AM
hondaless's Avatar
Default Re: it finally died (Noah *****)
Put your key in the ignition turn it to the ON position and you should here the fuel pump kick on. Like a zzzzzzz sound. If you turn the key to the ON position and don't here nothin then its prob your fuel pump. Or just take the fuel line off of your fuel rail turn the key to the ON position and see if any fuel starts to gush out if it doesn't your fuel pump is bad.
Old Aug 5, 2003 | 04:24 AM
bagged89hatch's Avatar
Default Re: it finally died (evilcrx)
you dont have to drop the tank to get to the fuel punp it is under the rear seat
Old Aug 5, 2003 | 04:48 AM
Default Re: it finally died (bagged89hatch)
i know its under the rear seat. the problem is that the thing under the seat is just the float. so out comes the gas tank.
Old Aug 5, 2003 | 04:51 AM
E-AT_me's Avatar
you sure it's not just your relay?
Old Aug 5, 2003 | 04:57 AM
Default Re: it finally died (Rexman)
relay? are you kidding me? what relay?
Old Aug 5, 2003 | 12:38 PM
goofball123321's Avatar
it could be the main relay cause that powers the fuel pump. When you put yhe key to pos 2 it is the main relay that powers the fuel pump for 2 seconds. A lot of ppl have been having this problem recently, Mine had the same problem, I changed the main relay and it was fine. Check to see if it makes the whirring sound in pos 2 though. You can get a new main relay at the honda dealer for 50-60 bucks.
Old Aug 5, 2003 | 07:28 PM
Default Re: (goofball123321)
well then istand corrected i though the pump wasaccesiblefrom that spot too. where exactly is the pump then
Old Aug 5, 2003 | 08:58 PM
4door_gsr_ftw's Avatar
Change the relay, Its much cheaper compared to the fuel pump, and its easier.
http://www.crxsi.com/resources...elay/
Go to that link and it will help you with the swap. I had to pay something like $70.43 or around that price. On the website it shows you how to re-solder it, its easier and safer (being that if you don't solder it good enough it will just fail). Its all the same on all CRX's, and easy too.
jastonian106
Feb 28, 2015 09:03 PM
thundernutz
Sep 20, 2009 12:37 PM
Cameron60
Jan 16, 2007 06:04 PM
Dee A Nine
Aug 24, 2004 02:45 PM
