What size socket for the axle bolt and where do I buy it.
Old Aug 5, 2003 | 12:46 AM
integraautox's Avatar
Default What size socket for the axle bolt and where do I buy it.
Ok I am going to do another tranny swap in a few weeks, this will be number 3. The last 2 times I did the tranny install with out taking my axels out of the rotor. I figured it would be a lot easier by taking off this bolt. What size is it and where do I buy it. I have checked home depot, napa, and autozone and they didn't have it last time I checked. Please help me out on this one.
Old Aug 5, 2003 | 01:36 AM
fergy016's Avatar
Default Re: What size socket for the axle bolt and where do I buy it. (integraautox)
I got mine at Sears/Home Depot. Anyplace that sells tools. It is a big socket. 22mm x 1.5
ForeignPart.com
acura, year, model, driveshaft&axle, CV Joint Nut.
Old Aug 5, 2003 | 01:41 AM
thaiphob's Avatar
Nikon!!!
Default Re: What size socket for the axle bolt and where do I buy it. (fergy016)
i swear the axle bolt was a 30mm?
Old Aug 5, 2003 | 01:45 AM
fergy016's Avatar
Default Re: What size socket for the axle bolt and where do I buy it. (thaiphob)
i agree i think it is 30 also.
Old Aug 5, 2003 | 02:01 AM
fergy016's Avatar
we were both wrong.
c-speed
read step 1, that right there shows that the nut is 32 mm
Old Aug 5, 2003 | 02:46 AM
97hb's Avatar
32mm or 1.25 inch
Old Aug 5, 2003 | 07:16 AM
cover94's Avatar
Default Re: What size socket for the axle bolt and where do I buy it. (97hb)
yup, when i did mine, the axle bolts were 32 mm
Old Aug 5, 2003 | 07:35 AM
tilt's Avatar
Default Re: What size socket for the axle bolt and where do I buy it. (cover94)
It is 32mm people.
Old Aug 5, 2003 | 08:03 AM
Chris's Avatar
Default Re: What size socket for the axle bolt and where do I buy it. (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">It is 32mm people. </TD></TR></TABLE>
YUP. and also remember to remove the stake... unless you have a good IMPACT gun.
Old Aug 5, 2003 | 08:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What size socket for the axle bolt and where do I buy it. (Chris)
That stake will not hold up to the force of a 4-ft. or longer breaker bar
Also I think I bought mine at Pep Boys, AutoZone should have it also. 32mm 1/2" drive.
Old Aug 5, 2003 | 09:59 AM
mingchi69's Avatar
I to Smooch Pickle
Default Re: What size socket for the axle bolt and where do I buy it. (PatrickGSR94)
the stake might not.. but i've had a couple reallie stuborn axle nuts.. that when used with a 4 ft breaker bar.. the breaker bar broke.
Old Aug 5, 2003 | 11:38 AM
INTEGRAMIKE's Avatar
Default Re: What size socket for the axle bolt and where do I buy it. (mingchi69)
i got on off with a chisel and a dremel tool ,but that would have to be the last thing i would recommend trying. Sometimes the impact wrench just wont take them off.
raverx3m
Classic Hondas
Nov 17, 2010 07:36 PM
eg6civic1538
May 17, 2007 03:32 PM
yh23
Jun 8, 2005 06:23 PM
hybrid515
15
Jun 9, 2004 07:18 PM
FUP23
Feb 16, 2002 03:05 PM
