Can i weld this fitting on my TURBO OIL OUTLET FLANGE?
Old Aug 4, 2003 | 11:07 PM
reignofchaos's Avatar
Default Can i weld this fitting on my TURBO OIL OUTLET FLANGE?
I WANT TO WELD THIS FITTING BELOW.............
to my oil return flange on my TURBO, like in this pic.
see, i don't want to do what this guy is doing, that's dangerous to me, so i want to saw the metal tube off the flange and weld that fitting on top! is it possible? and also what material should i use? how can i check what material my oulet flange is?
Old Aug 4, 2003 | 11:56 PM
5STAR3's Avatar
Default Re: Can i weld this fitting on my TURBO OIL OUTLET FLANGE? (reignofchaos)
just do braided lines....
much better
Old Aug 4, 2003 | 11:59 PM
Dee's Avatar
Dee
ummm....
Buy the 1/2" npt outlet for the turbo and screw a 1/2" to -10 adapter into the oil outlet on the turbo.
Modified by Dee at 4:29 AM 8/5/2003
TurboDANDEE's Avatar
hey make an adaptor plate for the outlet that has a 1/2 in. hole. then u buy a 1/2 in. fitting with whatever AN size you want...
Old Aug 8, 2003 | 11:47 AM
luckypon7's Avatar
Default Re: (TurboDANDEE)
if it is aluminum i don't think you can, it will burn and melt.
kaohli_yang
Nov 18, 2007 05:44 PM
herde1724
Jul 21, 2004 06:53 PM
reignofchaos
Jul 31, 2003 07:48 PM
civ96
May 21, 2003 03:56 PM
