will 99 si injectors work in my 91 crx si b16a1
i have a set of 99 si injectors, and have a 91 crx si w/a b16a1 swap, will the injectors work in my car, or i need different ones. and what kind do i need. thanks
No, these injectors will not work because they are saturated inj. You will need peak and hold style injectors which comes off of 90-91 Integra or the 1st gen B16a
yes those injectors WILL work. they are not drop in parts however.
you will need to get the proper clips for the injectors (4th gen civic injector clips are different), and you will need to rewire your injectors to remove the injector resistor box from the circuit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper4dr »</TD></TR><TR><TD CLASS="quote">yes those injectors WILL work. they are not drop in parts however.
you will need to get the proper clips for the injectors (4th gen civic injector clips are different), and you will need to rewire your injectors to remove the injector resistor box from the circuit.</TD></TR></TABLE>
So pretty much NO.
So pretty much NO.
stockhatch91
Nov 22, 2004 03:59 PM
psicrxsi
Sep 14, 2001 06:49 AM
