Anybody running endless calipers?
Old Aug 4, 2003 | 08:04 PM
Black R's Avatar
25 Year Member
Default Anybody running endless calipers?
4 or 6 piston?
I'm asking out of curiousity more than anything.....
It'd be interesting to see what the smallest rim is that would clear them.....
Old Aug 4, 2003 | 08:07 PM
BlueR's Avatar
Default Re: Anybody running endless calipers? (Black R)
i say you would have to start with a 16in rim
Old Aug 4, 2003 | 08:45 PM
Tweakmeister's Avatar
Default Re: Anybody running endless calipers? (BlueR)
send the Sp00ms this way
Old Aug 4, 2003 | 08:52 PM
Kengs's Avatar
ax Ben @ AJR
Old Aug 4, 2003 | 09:04 PM
B2FiNiTY's Avatar
I knew of one person. He ran 17" volk se-37ks
Old Aug 4, 2003 | 10:28 PM
Spikey's Avatar
Default Re: Anybody running endless calipers? (B2FiNiTY)
the 4pot will clear 15" rims, but u will need spacers... crazy spacers and long wheel studs
Old Aug 5, 2003 | 05:49 AM
bryant's Avatar
Default Re: Anybody running endless calipers? (Spikey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spikey &raquo;</TD></TR><TR><TD CLASS="quote">the 4pot will clear 15" rims, but u will need spacers... crazy spacers and long wheel studs</TD></TR></TABLE>
Yep freind has 4 pot with 15's extended studs and wheels spacers. Clears just fine now
Old Aug 5, 2003 | 10:36 AM
Flux's Avatar
Default Re: Anybody running endless calipers? (Bryant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">
Yep freind has 4 pot with 15's extended studs and wheels spacers. Clears just fine now </TD></TR></TABLE>
what wheels, what offset, and what size spacers is he using?
Old Aug 5, 2003 | 10:40 AM
Initial_E's Avatar
Default Re: Anybody running endless calipers? (Flux)
I am using 4 pot with Mugen 16" +43 offset.
Old Aug 5, 2003 | 10:56 AM
zer0zer0 TypeR's Avatar
Default Re: Anybody running endless calipers? (Initial_E)
what's the price range for the 4 pot setup?
Old Aug 5, 2003 | 01:26 PM
bryant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
what wheels, what offset, and what size spacers is he using?</TD></TR></TABLE>
Volk Ce28's, +42 i think and a wheel spacer im not sure of the size.
Old Aug 5, 2003 | 01:56 PM
Initial_E's Avatar
Default Re: Anybody running endless calipers? (zer0zer0 TypeR)
About 15000HKD = 1928 USD. That's including calipers, S/S brake lines and slotted rotors.
Old Aug 6, 2003 | 04:32 AM
Black R's Avatar
25 Year Member
.....nobody has pics, dimension analysis/ schematics?
Many companies provide these to aid in proper wheel selection.....
Old Aug 6, 2003 | 05:15 AM
bryant's Avatar
Here are som pics:
old endless rotors
Old Aug 6, 2003 | 05:31 AM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">Here are som pics</TD></TR></TABLE>
Nice. Are those the 4 or 6 piston? They look huge.
Old Aug 6, 2003 | 08:57 AM
Lucky-R's Avatar
i'd be more curious to know if there is a difference between these and the spoons in performance over stock...
Old Aug 6, 2003 | 09:40 AM
Type R 2c's Avatar
Default Re: Anybody running endless calipers? (picasso)
Gosh i want Endless so bad...i saw the whole kit for Mugen...$1,300. not bad for the whole kit.
Old Aug 6, 2003 | 09:49 AM
itr-j's Avatar
Default Re: Anybody running endless calipers? (Type R 2c)
very nice
Old Aug 6, 2003 | 09:52 AM
purplehazek4's Avatar
Default Re: Anybody running endless calipers? (itr-j)
the "d jac" ek9 in japan is running endless calipers on a 15x7.5 cp-o35 +40 with a spacer.
Old Aug 6, 2003 | 03:33 PM
bryant's Avatar
Nice. Are those the 4 or 6 piston? They look huge.</TD></TR></TABLE>
Old Aug 6, 2003 | 03:47 PM
euclid's Avatar
can you use stock rotors with endless calipers? are the brake pads the same size as stock too?
Old Aug 6, 2003 | 03:52 PM
bryant's Avatar
Default Re: Anybody running endless calipers? (euclid)
My friend is using stock rotors. I dont know about pads. I think hes using endless pads.
They are awsome breaks. The only thing i dont like so much about them is you have to wait for them to heat up and get some good breaking in before they work to their full potential.
Old Aug 6, 2003 | 04:00 PM
Black R's Avatar
25 Year Member
Default Re: Anybody running endless calipers? (purplehazek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplehazek4 &raquo;</TD></TR><TR><TD CLASS="quote">the "d jac" ek9 in japan is running endless calipers on a 15x7.5 cp-o35 +40 with a spacer. </TD></TR></TABLE>
.....what size spacer? And are these the 4-pot? What size rotors?
Old Aug 6, 2003 | 05:44 PM
ITRJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....nobody has pics, dimension analysis/ schematics?
From Endless' website (modified by yours truly )
Dimensions listed are for a Type R "System Kit" which includes straight 6-slotted rotors, 4 pot calipers, ss lines, street or circuit pads and adaptors.
Avg weight of the 4 pot caliper is 4.72 lbs.
Endless also lists the 4 pot caliper size as "255 mm x 140 mm x 70 mm" but that seems to conflict with the diagram above.
Old Aug 6, 2003 | 07:38 PM
baonest1's Avatar
i have endless brake pads... lifetime warantee from autozone.
sorry, just tried to be funny... ??
no??
