B18 Swap
i'm in the process of doing a ls swap into my hatch and i heard that i could just pinout the ecu. just get a helms manual for your ex and one for a teg. if you decide to stick with the harness than good luck cause it's gonna be a MAJOR PIA!
Easiest thing to do is use your complete factory wireing harness, fuel injectors, and computer. You can get your ecu chipped with LS fuel/timing maps. Pretty much
the only thing you would need extra, is a 90-91 ls distributor (see sig
litlekikr
10
May 6, 2003 06:24 PM
