d series tranny question?
Old Aug 4, 2003 | 07:53 PM
crx88fast's Avatar
Default d series tranny question?
Will any tranny off of any d series engine fit on any other dseries engine? i have a 88 crx with a sohc zc engine and i am goin to put in a tranny from a 93 civic si with a d16z6... will this work ok? let me know as soon as possible as i am looking to buy tommorrow... thanks.... Jay
Old Aug 4, 2003 | 07:58 PM
1990hondaHF's Avatar
Default Re: d series tranny question? (crx88fast)
pre 91's are cable and post 91's are hydro....unless you use some sort of adapter, these years will not mix.
Old Aug 4, 2003 | 08:00 PM
crx88fast's Avatar
Default Re: d series tranny question? (1990hondaHF)
so what would be the best thing to do?>
Old Aug 4, 2003 | 08:18 PM
Timmah!!'s Avatar
get a good 88-91 Si tranny with clutch to match the year if the tranny
Old Aug 4, 2003 | 08:42 PM
I8ayellowcrayon's Avatar
Hey man, Honda parts are kinda scarce in NW Ark huh? Since yours is an 88, if you put an 89-91 tranny on there, you'll have to have the clutch and tranny from the 89-91 also. The 88 has 21 splines and the 89-91 has 20. If you can't get ahold of anyone about a tranny, I have a couple numbers for you to call, PM me. They are both in Springdale though.... Not too far.
Oh and by the way, I would suggest an Si, but I have a DX that I may have for sale after a while. I bought it on Sunday, but have an Si with a bad case lined up, but I have no clue when I'm going to get it. Keep in touch with me if you still need it after a while.
Old Aug 4, 2003 | 08:45 PM
Oh yeah, thats right, Trial Members can't PM. Email me at I8ayellowcrayon@yahoo.com .
Old Aug 4, 2003 | 08:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx88fast &raquo;</TD></TR><TR><TD CLASS="quote">so what would be the best thing to do?
go here: http://www.ebay.com
and here: http://www.car-part.com/
and here: https://honda-tech.com/zeroforum?id=10
Old Aug 5, 2003 | 12:44 PM
crx88fast's Avatar
so what other cars could i get a tranny from besides the crx?
Old Aug 5, 2003 | 12:55 PM
EL Vap133's Avatar
an 88-91 Civic....
Old Aug 6, 2003 | 08:30 PM
crx88fast's Avatar
Default Re: d series tranny question? (Vap133)
ok i found an 88 crx si tranny with 70k miles but they want 450 for it... is this too much in your opinion?
Old Aug 6, 2003 | 11:22 PM
Louie B.'s Avatar
I wouldn't pay that much unless it's freshly rebuilt with a waranty.
I paid 100 for my si tranny, and a friend of mine has a shop and they can get brand new (well, rebuilt w/ all new parts) for less than 500.
What's wrong with your tranny? unless the case is cracked you could probably rebuild yours. a lot of people get nervous about working on trannies, but it's a lot easier than you might think. IMO easier than rebuilding an engine.
Old Aug 7, 2003 | 05:44 AM
keithv's Avatar
Default Re: d series tranny question? (thumpu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">What's wrong with your tranny? unless the case is cracked you could probably rebuild yours. a lot of people get nervous about working on trannies, but it's a lot easier than you might think. IMO easier than rebuilding an engine. </TD></TR></TABLE>
so true...rebuilding an engine requires a lot more care and is much more tedious.
Old Aug 7, 2003 | 12:24 PM
crx88fast's Avatar
i dont know... it makes some rattling noises and it blows tranny fluid out... gets on the clutch and is making it slip... just put in the new clutch and the tranny got really bad and was leaking a lot... slippin like crazy.... how much do you think to have it rebuilt&gt;?
Old Aug 7, 2003 | 08:51 PM
Louie B.'s Avatar
probably just need to replace the input shaft bearing.
the bearing itself is about $7.00
If you befriend a local tranny shop mechanic, you may be able to get him to order you a rebuild kit. I got a complete kit with all new bearings, seals, and syncros for less than $200.00
Modified by thumpu77 at 10:08 PM 8/7/2003
Old Aug 8, 2003 | 08:46 AM
bagged89hatch's Avatar
buy a trans from me
Old Aug 10, 2003 | 10:01 PM
KOOL-AID's Avatar
i have question for everybody ok i got the d16z6 and im getting the a clutch and flywheel package from clutchcity but will the flywheel from a 91 civic fit on the d16z6 i know i have to use the same year clutch as the tranny but not sure on the flywheel thanks!!
Old Aug 10, 2003 | 10:15 PM
Louie B.'s Avatar
Default Re: (KOOL-AID)
the flywheel is the same from 90-2001 so if your tranny is a 90-91, you can get any flywheel from 90-01.
if your tranny is an 89, get the 90-91 clutch and the 90-01 flywheel. it will fit if you get them all. If you're getting the smaller 89 clutch, you'll need the 88-89 flywheel.
if your tranny is an 88, you can use a 90-91 pressure plate and 90-01 flywheel if you use an 88 accord clutch disk. If your using the smaller 88 civic clutch and PP, you'll need the 88-89 flywheel.
Old Aug 10, 2003 | 10:23 PM
KOOL-AID's Avatar
Default Re: (thumpu77)
thanks for your reply man i appreciate it i have a 91 civic so i'll just get the whole package for that year!!! thanks for the quick reply man
whole9
27
Dec 24, 2006 12:01 AM
sohcvtec91hatch
Aug 13, 2006 06:08 PM
jdmCivic925
Oct 20, 2003 11:07 PM
VTgringo
15
Aug 6, 2003 11:29 PM
REDBARON
14
Dec 3, 2002 06:30 AM
