LOOK.. FI E/M Fuse blows.....
Yea and I wish I could correct the problem. It really sucks because I live in Texas and I can hardley stand 5 minutes under my dash with my body twisted up trying to follow this stupid wire. It was 103 degrees out today.
sort of laid out- the yellow/black goes to the 4 injectors, EACV, purge control solenoid, and the main relay
the red/green goes to the distributor as the yel/green wire (ignition input signal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R »</TD></TR><TR><TD CLASS="quote">sort of laid out- the yellow/black goes to the 4 injectors, EACV, purge control solenoid, and the main relay
the red/green goes to the distributor as the yel/green wire (ignition input signal)</TD></TR></TABLE>
.... and the yellow/black wire also goes to IG1 and IG2 which is where I've stated a ground occuring with both wires. I'm not showing any problems with my injectors, Iacv, or purge control solenoid being grounded.
Suck my DX
11
May 12, 2007 01:13 PM
