back from baghdad!
Old Aug 4, 2003 | 06:39 PM
integRated109's Avatar
Default back from baghdad!
ok, just got back from the hot dry place(no, not so-cal) and the ol teg wont start. if i jump it it starts, but wont charge the battery. it will run fine all day as long as i dont cut it off. ive tried 2 batteries and same result. alternator you think? im super beat down and jet lagged, and dont feel like thinking very hard right now so any ideas will be appreciated.
Old Aug 4, 2003 | 06:42 PM
YellowKahuna's Avatar
Default Re: back from baghdad! (integRated109)
wellcome back
and take a rest.
Old Aug 4, 2003 | 06:43 PM
slowman's Avatar
I took way too long
Default Re: back from baghdad! (YellowKahuna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowKahuna &raquo;</TD></TR><TR><TD CLASS="quote">wellcome back
and take a rest. </TD></TR></TABLE>
Yeah, that'd be the best thing to do right now.
Glad you're back safe
Old Aug 4, 2003 | 06:45 PM
jonas's Avatar
happen to be in the same group as a person named Jason Amos? he's a corpseman.. just wonderin
Old Aug 4, 2003 | 06:46 PM
01-1293's Avatar
Default Re: (jonas)
100 % definately sounds like an alternator........I let my crx sit for 7 months and the alternator went bad
Old Aug 4, 2003 | 06:50 PM
thashadow's Avatar
Default Re: (01-1293)
alternator, battery terminals..
one of the two
welcome back
Old Aug 4, 2003 | 06:51 PM
PlikityPLAH's Avatar
what part az you at?
Old Aug 4, 2003 | 06:58 PM
Default Re: back from baghdad! (PlikityPLAH)
thanks all, im at Ft Huachuca, south of tucson. ill post some pics soon as i get my own computer out of storage.
Old Aug 4, 2003 | 07:10 PM
MK Ultra's Avatar
Welcome back.
It could be corrosion on the battery terminals has migrated to the battery cables (if there was a big buildup of gunk on the terminals).
Old Aug 4, 2003 | 07:26 PM
RedlinedVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 &raquo;</TD></TR><TR><TD CLASS="quote">100 % definately sounds like an alternator........I let my crx sit for 7 months and the alternator went bad</TD></TR></TABLE>
Sounds like a bad battery and not a bad alternator... he said it's fine as long as it's running, but it won't hold a charge... which means dead battery.
Old Aug 4, 2003 | 07:40 PM
FJO3's Avatar
Default Re: (RedlinedVTEC)
did anyone who recommended a new battery actually read the entire first post? he has already tried 2 other batteries and gotten the same result.
Anyways I also say that it sounds like your alternator is the problem
Old Aug 4, 2003 | 11:59 PM
Default Re: (2000R#1355)
Whoops my bad, just skimmed his post, yeah if you've tried two batteries, then definately check the alternator.
Old Aug 5, 2003 | 12:21 AM
Spoond TEG's Avatar
Sounds Like ALT. Were both Batteries NEW
Old Aug 5, 2003 | 05:55 AM
Philly_NBP_R's Avatar
Default Re: (Spoond TEG)
Welcome Home
Check the battery voltage while the car is running - most likely the alternator isn't charging... You'd be suprised how long a car can run w/ a dead alternator and a jump start
Old Aug 5, 2003 | 06:04 AM
00MRSi's Avatar
Default Re: (Philly_NBP_R)
Welcome home.
Thank you for serving our country.
Sounds like a possible alternator.. Good luck and get some rest..
Old Aug 5, 2003 | 06:13 AM
H-PIMP's Avatar
Default Re: (00MRSi)
Welcome back soldier!
get a new alt.
Old Aug 5, 2003 | 08:06 AM
VTECPWR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi &raquo;</TD></TR><TR><TD CLASS="quote">Welcome home.
Sounds like a possible alternator.. Good luck and get some rest.. </TD></TR></TABLE>
Old Aug 5, 2003 | 08:14 AM
cw98typer's Avatar
Default Re: (VTECPWR)
Welcome back man Definatley check Alternator and battery terminals.
Old Aug 5, 2003 | 03:24 PM
TOR_ITR's Avatar
I had the same problem after the winter, what I did might be stupid but it works...I just keep on driving my car after a jump-start, it took me about 3 nights for doing that(1-2hrs everynight) and everything back to normal after that.
I know it is kind of stupid but it still fun to drive around with my R. ( but make sure don't turn off your car when you stop for a coffee or something else.)
young_tuner
Jul 9, 2008 08:44 PM
all_motor
12
Feb 13, 2006 02:45 AM
spicoli
Audio / Security / Video
11
Aug 24, 2004 09:27 AM
cademan
Jul 13, 2004 07:38 AM
civictyper96
10
May 15, 2004 12:22 PM
