3rd gear grinding???
Old Aug 4, 2003 | 11:25 AM
1.8Tities's Avatar
Default 3rd gear grinding???
I'm having a prob with my 3rd gear engagement, and it grinds when I shift at above 3k rpm or sometimes if i do it really quick. Could this be a sign of bad synchro? It's fine when i shift slowly and below 3k but that kinda suck.. I can't wind up engine and shift above 3k.. To add to this dilema, I have a DC sports shortshifter. Do you guys think it might have to do with my DC too? Help.
Old Aug 4, 2003 | 11:29 AM
Ivan's Avatar
senior gold member
Default Re: 3rd gear grinding??? (4thGSi)
try and change the MTF. it helps sometimes.
Old Aug 4, 2003 | 11:33 AM
SIRX's Avatar
sounds like the sync's are going. try Honda MTF or GM syncromesh. good-luck
Old Aug 4, 2003 | 11:36 AM
1.8Tities's Avatar
Default Re: 3rd gear grinding??? (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">try and change the MTF. it helps sometimes.</TD></TR></TABLE>I changed the MTF like 5 months ago.. Just to let you know.. But I'll try that..
Old Aug 4, 2003 | 11:46 AM
civictuned's Avatar
WHAT DOES MTN STAND FOR. THANKS FOE LIFE!!!!!!!1
Old Aug 4, 2003 | 11:47 AM
projecthybrid04's Avatar
Default Re: 3rd gear grinding??? (civictuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuned &raquo;</TD></TR><TR><TD CLASS="quote">WHAT DOES MTN STAND FOR. THANKS FOE LIFE!!!!!!!1</TD></TR></TABLE>
its MTF - Manual Transmission Fluid, just get the OEM honda
Old Aug 4, 2003 | 12:59 PM
1990hondaHF's Avatar
Default Re: 3rd gear grinding??? (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote"> try GM syncromesh. </TD></TR></TABLE>
I had the same problem...tried this stuff.....and no more grind!!!!
Old Aug 4, 2003 | 01:04 PM
Ef Whore's Avatar
Default Re: 3rd gear grinding??? (1990hondaHF)
GM Syncromesh= , stopped my 1st to 2nd grind when I bury the needle. Shifts way smoother too. Part #12345349, trust me it works.
Old Aug 4, 2003 | 01:39 PM
Timmah!!'s Avatar
Default Re: 3rd gear grinding??? (Ef *****)
I have 2q of the GM stuff waiting to go in. But I need to replace the seals be for i do that, and Im broke.
But It should get rid of my grind into 3rd. It has for everyone that I know that has used it.
Old Aug 4, 2003 | 01:48 PM
1.8Tities's Avatar
Default Re: 3rd gear grinding??? (azroth)
Where can I get this GM syncromesh tranny fluid? I used Honda MTF all the time.
Sounds like GM had a pretty good review from few h-techers..
mcc361
Sep 4, 2007 12:38 AM
Art Vandeleigh
Honda S2000
54
Jun 2, 2007 06:55 PM
bluesaint
Aug 9, 2006 06:07 AM
kungura
Honda S2000
16
Jun 27, 2005 08:44 PM
jerrywidening
11
Jan 15, 2004 10:29 PM
