Brake problems !! Need some help
i was pulling into a gas station and appied very light pressure to the pedal and the pedal went to the floor. I check the calipers and rear drums for any fluid and didn't see any so I checked the fluid level. It seem a little low but not bad. I drove the car home (carefully) applying the brakes so that I could see if the level dropped by the time I got home so that I knew if I was loosing fluid or not. The ground was wet so I fully depressed the brakes a couple times and if I was around 5 mph, I could lock the brakes up, but only when the pedal was all the way to the floor. When I got home I checked the calipers and drums again, still no fuild and the fuild leve was the same. It sounds like the MC, but I just wanted to get some more ideas from you guys before I go and buy a new MC and swap it out.
Thanks in advance !!
micah_m
Suspension & Brakes
Oct 13, 2014 09:11 PM
Chilloutdamn
Nov 4, 2008 03:24 AM
