Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- How to Replace Windshield Molding
Step by step instructions for do-it-yourself repairs
Anyone Know How To Replace Rubber Moldings on the Windshield of an EG?
Has anyone every replaced the rubber moldings on an EG Civic that go around the windshield? Does the windshield need to come off? Any thing special that needs done to put them on?
ANY help would be appreciated. Mine are dry, cracked and nasty and I finally have my replacements.
Thanks for the help.
They can be removed w/o removing the windshield. They are held in by clips...dang I'd scan my Helms book to scan the picture.
I used some window trim tools to release the clips from the moulding.
** might help
Modified by SLPR at 8:04 AM 8/5/2003
** might help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedHatch »</TD></TR><TR><TD CLASS="quote">replacing those things SUCK
just use alot of black weatherstrip adhesive by 3M....</TD></TR></TABLE>
Where do you put this stuff on? Around the window?
well seeings how i just had my front windshield replaced 2 seconds ago i think i have a fair idea..
just pop off the side moldings.. little clips hat pop off if you just pull up on them (unless there is 3m glue behind them already, then there a bitch)
as for the top just peal it off, get the 3m windshield adhesive, put it down where the moldings go, carefully put the moldings back in matcing up the clips and pop it in, the top strip should be done 2nd after one side, push the little tab into the side molding, then carefully lay out it across the winshield adhiesive and push down flush to windshield
put the last side molding on and clean up all the excess adhesive and your done
Lookinaround
Aug 1, 2006 08:10 AM
Grip
Nov 1, 2004 09:33 PM
