how do i identify an ls tranny from a gsr tranny......
Old Aug 4, 2003 | 10:16 AM
projecthybrid04's Avatar
Default how do i identify an ls tranny from a gsr tranny......
is there a way to tell on by lookin at it, i know the obvious way is to drive it but right now the motor is blown, please help
Old Aug 4, 2003 | 02:19 PM
Blaze45's Avatar
Brrraaaap!
Default Re: how do i identify an ls tranny from a gsr tranny...... (projecthybrid04)
Well, I think that H/A didnt make an cable GSR tranny, so right there, if its a hydro that eleminates that. Unless they took the LS tranny apart and put the GSR guts in it. The Clutch cable type LS says S1 on it.
Blaze
Old Aug 4, 2003 | 02:27 PM
Bspec18's Avatar
Default Re: how do i identify an ls tranny from a gsr tranny...... (Blaze45)
They did make a cable GSR tranny in 93 i believe. The tranny i have is a 96 GSR(hydro) it says Y80 hope that helps
Old Aug 5, 2003 | 08:11 AM
Default Re: how do i identify an ls tranny from a gsr tranny...... (Bspec18)
well its a hydro tranny, im trying to identify the difference between the newer ls and the newer gsr tranny
Old Aug 5, 2003 | 08:28 AM
b20_ed's Avatar
my gsr tranny is an s80? 98 too
Old Aug 5, 2003 | 08:44 AM
_Not_So_Nice_Guy's Avatar
Default Re: how do i identify an ls tranny from a gsr tranny...... (b20_EK)
can't tell from the case, or the S/Y80 on the case. Only way to tell is either to put it in first and rotate the input shaft and count how many times it turns compared to the output shaft. Do some math on the known GSR and LS gear ratios to figure out the same. Could also use reverse since it is a 3:1 ratio, and just do the math on the 4.40 and 4.266 FD.
Old Aug 5, 2003 | 09:34 AM
NeoGSR's Avatar
Default Re: how do i identify an ls tranny from a gsr tranny...... (Nice_Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nice_Guy &raquo;</TD></TR><TR><TD CLASS="quote">can't tell from the case, or the S/Y80 on the case. Only way to tell is either to put it in first and rotate the input shaft and count how many times it turns compared to the output shaft. Do some math on the known GSR and LS gear ratios to figure out the same. Could also use reverse since it is a 3:1 ratio, and just do the math on the 4.40 and 4.266 FD. </TD></TR></TABLE>
now there's a excellent piece of advice
Old Aug 8, 2009 | 01:34 PM
fireblaze2k1's Avatar
How do you put it in gear if it's out of the car?
Old Aug 8, 2009 | 01:50 PM
KWayRacing's Avatar
by using the shift shaft
Old Aug 8, 2009 | 04:55 PM
So the S80-3002780 means nothing?
Old Aug 9, 2009 | 02:05 AM
95DC2GS-R's Avatar
Nope.. the LS/GSR/Type R trans case is all the same.. and the LS/GSR will some times both say S80 or Y80.
Your best bet is checking the VIN tag. If it starts with JH4DC2, it's a GSr tranny, if it's JH4DC4, it's an LS.
Not So Nice Guy's info will also help you.
K7-1Ktrevor
Jun 8, 2010 11:30 PM
777sC
Mar 2, 2007 10:05 AM
ONELIFEMOTORSPORTS
Nov 14, 2006 05:29 PM
Beau Gotti
Oct 3, 2006 09:32 PM
Mires
Jan 10, 2003 06:42 PM
