Stock cams with Mugen ECU???
Old Aug 8, 2001 | 08:13 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Stock cams with Mugen ECU???
I have heard of the stock cams being able to produce 200+whp using Mugen parts. With valve train upgrades,ECU,and higher comp headgasket is this possible? For $1,300 that ECU better be good for something. Any pros/cons to using the Mugen ECU?
Old Aug 8, 2001 | 08:19 AM
Blade's Avatar
New User
Default Re: Stock cams with Mugen ECU??? (ActiveAero)
It's not possible. You'd need more mods to reach 200whp. The ECU is overpriced for the same money you can get the Apex PowerFC which is a tuneable ECU.
Old Aug 8, 2001 | 08:22 AM
ZygSpeed's Avatar
That's the $1300 question, isn't it.
Nice results (by moving VTEC and redline), though you might need to up the fuel pressure a bit for best results (just a few lbs).
I'm considering getting an Apex-i Power FC for a future turbo job on my R, so I MIGHT be letting the Mugen ECU go (won't be cheap in any case). ed
Old Aug 8, 2001 | 08:38 AM
Dipshit Dan's Avatar
Default Re: Stock cams with Mugen ECU??? (zygspeed)
Do a search. Didn't we just cover this last week?
Old Aug 8, 2001 | 10:17 AM
Big Phat R's Avatar
Default Re: Stock cams with Mugen ECU??? (God)
i was waiting for that comment.
i think people post just to generate conversation. oh well.
Old Aug 8, 2001 | 10:21 AM
Hooch'n's Avatar
Default Re: Stock cams with Mugen ECU??? (Big Phat R)
How about the Comptech ECU? Then spend your money on other mods, would that work?
Old Aug 8, 2001 | 10:23 AM
ZygSpeed's Avatar
Default Re: Stock cams with Mugen ECU??? (8400-RPM)
Comptech would prolly be OK.
The Mugen ECU wont trip the CEL (at least for test pipe purposes).
Old Aug 8, 2001 | 10:28 AM
EPGONZALEZ's Avatar
if you are on a budget i wouldnt recommend the mugen ecu..you can get similar results with other equipment...
Snoppy
Feb 26, 2004 03:27 AM
ChapR
Jan 6, 2003 07:58 PM
slowassR
Aug 1, 2002 05:24 PM
neveronlines2k
Jun 1, 2002 02:18 PM
