just removed vafc now runs ike crap!
Old Aug 4, 2003 | 07:56 AM
thehondaguru's Avatar
Default just removed vafc now runs ike crap!
Ok I took out my vafc to sell it and now the car runs like hell. I dont get it it was fine now it backfires and runs just like utter crap. I have now power between 8 and 3000 rpms. The check engine light is on and I dont remember how to get the code.
Old Aug 4, 2003 | 10:11 AM
Default Re: just removed vafc now runs ike crap! (95 lude)
please help!!!!!!
Old Aug 4, 2003 | 10:24 AM
prelittlelude's Avatar
k ill bite im here, em when you took the vafc out were you sure splice all the factory wires and put it back the way it was. you also may want to reset your ecu, im not sure how the vafc interacts with thte ecu but it may have "learned" to deal with the vafc being hooked up and now that it is gone the ecu is over compensating.
3 things to try:
1. check those wires and when ur sure they are right check them agian, if you have a wiring problem theres no point in even doing the next steps
2. reset the ecu buy either pulling the fuse, or taking the negitive off of the battery.
3. if reseting the ecu doesn't work and the car still runs like ****, and you REthrow the CEL , you need to check the code, and then go from there.
Old Aug 4, 2003 | 10:33 AM
CHK4TIX's Avatar
Default Re: just removed vafc now runs ike crap! (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">k ill bite im here, em when you took the vafc out were you sure splice all the factory wires and put it back the way it was. you also may want to reset your ecu, im not sure how the vafc interacts with thte ecu but it may have "learned" to deal with the vafc being hooked up and now that it is gone the ecu is over compensating.
3 things to try:
3. if reseting the ecu doesn't work and the car still runs like ****, and you REthrow the CEL , you need to check the code, and then go from there.</TD></TR></TABLE>
i would do almost every thing that prelittlelude said, except i would add check the codes first. then after you have them written down i would pull the ecu fuse. I would almost bet that is the problem, but you would already have the codes just in case.
Old Aug 4, 2003 | 10:34 AM
Default Re: just removed vafc now runs ike crap! (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">
i would do almost every thing that prelittlelude said, except i would add check the codes first. then after you have them written down i would pull the ecu fuse. I would almost bet that is the problem, but you would already have the codes just in case.</TD></TR></TABLE>
the man has a point, try it and let us know
Old Aug 4, 2003 | 02:18 PM
Elkins911's Avatar
how much for the VAFC???
Old Aug 5, 2003 | 07:30 AM
Default Re: just removed vafc now runs ike crap! (jz)
your right there is 2 wires you have to cut and put 2 different wires on the 2 different ends of the cut wire. If you can make sense of the great. ANyway I am gonna resplice those wires and see what happens. Thanks for the help!
Old Aug 5, 2003 | 09:58 AM
aight its fixed Ihad to reconnect 3 wires back to each other. I recomend getting the wire harness for the ecu for anyone getting a vafc. Now my harness is all f'd up but hey it works!
Old Aug 5, 2003 | 10:02 AM
glad to hear it, wiring is kinda important hehe good work
Old Aug 5, 2003 | 10:42 AM
Elkins911's Avatar
Default Re: just removed vafc now runs ike crap! (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">how much for the VAFC??? </TD></TR></TABLE>
Old Aug 5, 2003 | 08:32 PM
you are right. I was just talking about the actual wire harness for the ecu. Not for the vafc. But anyway thanks for the help again
Old Aug 5, 2003 | 08:47 PM
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I recomend getting the wire harness for the ecu for anyone getting a vafc</TD></TR></TABLE>
If you could fine someone that makes one for 4th gens..
Old Aug 12, 2003 | 07:06 AM
KCHybrid's Avatar
Default Re: (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">
If you could fine someone that makes one for 4th gens.. </TD></TR></TABLE>Wouldnt the one by fields for the teg work? They make one for the obd p72, the only thing is you might have to add a wire for the egr. Not 100% sure however, I am making/made a home made harness.
Old Aug 12, 2003 | 08:05 AM
Default Re: (KCHybrid)
I think it would work but I wasnt paying attention. They do only make the harness for the 5th gen not the fourth
Old Aug 12, 2003 | 08:44 AM
iakona's Avatar
where'd you find your VAFC harness for a 5th gen?
Old Aug 12, 2003 | 08:54 AM
KCHybrid's Avatar
Default Re: (iakona)
I am pretty sure inline 4 carrys all the models of them. Going to run you about 160 bucks shipped.
LKSi
Mar 30, 2007 12:47 PM
dzzrunnin411
Jan 20, 2007 10:35 AM
Nisif
Jan 10, 2005 07:06 PM
96gsrlmo
Apr 15, 2004 05:37 PM
billk2k
Mar 7, 2003 12:03 PM
