What are the obvious signs I need a valve adjustment...?
Old Aug 4, 2003 | 12:37 AM
FD3S's Avatar
Default What are the obvious signs I need a valve adjustment...?
Besides mileage and maintainence issues. I'm asking about the tell-tale signs. Are the VTEC crossovers delayed? i.e. 4600 and 6200 vs. 4400 and 5800. Is gas mileage decreaced? I am wondering because my car seems to be trying to tell me something. I know I need one but haven't gotten around to it.
Old Aug 4, 2003 | 01:10 AM
.xcalibur.'s Avatar
Default Re: What are the obvious signs I need a valve adjustment...? (FD3S)
Abnormal engine ticking coming from the head. If its too loud then the valves are a lil loose and need tightening. As for the secondaries being delayed, they work on vacuum, so you might wanna check your lines and hoses.
Old Aug 4, 2003 | 11:02 AM
FD3S's Avatar
Default Re: What are the obvious signs I need a valve adjustment...? (.xcalibur.)
so i found out that there is a hesitation while in VTEC too. maybe it could be a dirty fuel filter?
help me out guys!
Old Aug 4, 2003 | 11:03 AM
Mark's Avatar
*Bounty Hunter*
I had a hesitation in mine, but i changed my oil as well as a muchly needed rotor in my dist. and now its fine !
luck i say shrug
Old Aug 4, 2003 | 04:54 PM
FD3S's Avatar
Default Re: What are the obvious signs I need a valve adjustment...? (94BlackCivicEX)
hmmm...maybe i should check the tech forum? i know someone can help me out here. this is after all a technical resource, or is everyone on GD&D?
Old Aug 4, 2003 | 05:14 PM
Havokmkr's Avatar
I'd say if you feel a loss in power and a delay in vtec engagement, just do the basics. Change distributor, rotor, wires, plugs, check all vaccuum hoses on the IM. This could be a number of things. It never hurts to replace something like your fuel filter anyway. Be more specific and maybe someone can help you. When's the last time you changed the things listed above? When was the last major tune-up? How many miles on the car and when was each part last replaced/serviced?
Old Aug 4, 2003 | 05:54 PM
FD3S's Avatar
Default Re: What are the obvious signs I need a valve adjustment...? (Havokmkr)
i recently changed out the plugs and wires so that probably isn't it. i'm at 50,xxx miles right now. I haven't done a "major tune up" per say, but I regularly maintain my car. Is it time to replace my distributor and rotor? I'm going to check the vacuum lines tonight. anything else to look out for?
young-richie
Aug 23, 2007 06:57 PM
boost'dsiR
Sep 14, 2005 05:39 AM
VtecDA9
Jul 8, 2003 06:36 PM
Frosty_spl
Feb 21, 2002 03:19 PM
