1/8 ls time slips
took the crx with stock ls to the 1/8 track here are the times. runnin 22x8x13 slicks at 14 psi and lsd. launching at 4500 and 5000 rpm. what can i improve so that my et's go down. should i try launching harder or lower tire pressure.
1st run- reaction .162 2nd run- reaction .164 3rd run-reaction-.237
60 ft-2.108 60 ft- 2.15 60ft-2.167
1/8 et-9.889 1/8 et-9.800 1/8 et-9.680
MPH-69.22 mph-73.06 mph- 71.65
My brother told me he got best results from launching his B16 CRX at 6500 rpm on slicks... Your times aren't too bad for a basically stock LS either. Just practice.
Try launching a little higher, like 7000 rpm. And lower your tire pressure a little. Just keep practicing until you get a combination that works. My best time in my LS CRX is 9.78 at 73 mph on crappy street tires. So I'd say you can get those times down to like 9.2-9.3. Good luck
With a stock ls swap in a 1900 lb car and slicks you "should" be low 9s out the door. My heavy integra gsr ran a best of 9.4 all motor on streets in the 1/8. Well that was with I/H/E. Just launch the hell out of it. And a 2.1 with slicks is not a good 60'. Most can get that with street tires. Some have even hit high 2.0s. My best with streets is a 2.1. You should atleast be in the 1.9s with that size slicks.
hey john@M&H i dropped 1 pound from 14 to 13 psi. launched a bit harder from 5000 rpm to 5500 here are my new 60ft's. thanks for the advise 60ft's went down. i was going to launch it harder but didn't get a chance. how hard should i launch next time and should i lower the psi just a bit more thanks.
reaction.....120 reaction.......168
60ft.......2.051 60ft...........2.081
1/8 ET.....9.858 1/8 et.......9.723
1/8 mph....70.53 1/8 mph.....71.29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">why are your reactions .100's it should be .500
work on that. </TD></TR></TABLE>
RT's have nothing to do with your ET.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
RT's have nothing to do with your ET.</TD></TR></TABLE>
o sorry im new to drag and this is an old post
My friend with a 94 LS (header/straightpipe/exhaust and GSR tranny) ran a best of 10.0 on normal crappy Falken Ziex. He was launching at around 3500.
You should be running better than that....
I have a LS motor in my EG hatch, just bolt-ons, LS tranny and on street tires..here's my best:
2.310 60' (i've managed to get a 2.2 60' in another run-with the same tires)
9.685 1/8
75.12 1/8MPH
15.025 1/4
93.22 1/4MPH
I'm sure if I were on slicks or drag radials i'd definately be in the 14s...especially with the 93mph trap! My Jimfab traction bar is on it's way and purchasing some slicks or radials soon...hope to hit much better times....
9.685 1/8
75.12 1/8MPH
15.025 1/4
93.22 1/4MPH
