**** How to install JDM carbon fiber window switches into your USDM integra ****
Old Aug 3, 2003 | 09:06 PM
black2001gsr's Avatar
Default **** How to install JDM carbon fiber window switches into your USDM integra **** 56k go away!!!!
* If the pictures aren't up please check back later, damn Imagestation *
Well everyone I finally did it. I recently purchased my JDM carbon fiber window switches and installed them today. The complete installation took about 2 hours, but I finally got it. I read in other posts that the JDM drivers side switch would not allow the auto roll down to work on the drivers side. I figured this out. However this involves dremeling. I'm am not responsible if anything goes wrong so please test fit everything and work slowly. Here it goes.
1. First begin by removing the 3 screws in the door panel:
2. Then pull along the bottom and sides of the door panel:
3. Remove the door panel by lifting up and back. Then unplug the 3 wires.
4. Take the a screwdriver and remove the screws that hold the switch.
5. On the passenger side you can easily install the JDM switch and here is the finished product You don't need to dremel anything or even use your USDM switch.
6.Now with the driver's side switch cover removed, carefully examine the difference between the USDM (right) and the JDM (left) switch covers. Notice how the bottom hole is in a different place.
7. Now lets look at the actually buttons. Again USDM (left) and JDM (right).
8. You will use the JDM carbon cover on the USDM control box. Do you see the "on button" that's red and black. Take the JDM button off and put it on the USDM button control box. You will need to do this because the JDM switch slants the opposite direction and it will have a giant opening
9. Take the dremel and remove the plastic from the USDM control box shown here.
10. Turn the box over and drill a hole pointed by the pencil.
11. Next dremel the areas where the screw will go into. They slant to the left but you will need them slanted to the right.
12. Ok now install the JDM carbon piece and USDM control box piece. Notice how I haven't installed the buttons. Installing just the black box first allows easier access to the screws.
13. Carefully look at the white plastic piece I circled in red. You will need to find a small plastic piece (rectangular shape about 4mm) and crazy glue it on the black lever as shown. This will allow the pass on/off button to work. If you don't do this your button will not work.
14. Now install the buttons and cover.
14. Re-install the plugs and install the door panel. Here is the finished product!
Sweetness!!!!
Modified by black2001gsr at 4:52 PM 8/5/2003
Modified by black2001gsr at 10:55 PM 8/6/2003
Old Aug 3, 2003 | 10:26 PM
thaiphob's Avatar
Nikon!!!
Default Re: **** How to install JDM carbon fiber window switches into your USDM integra **** 56k go away!!!!
good job the detaled pics!!
Old Aug 3, 2003 | 10:27 PM
Thanks I hope this helps
Old Aug 3, 2003 | 10:53 PM
OutLaw MR's Avatar
Damn I didn't even know that the JDM's came with it.Looks pimp,good job!
How about the A/C vent does it come c/f also?where can I get one?
Old Aug 3, 2003 | 11:00 PM
kepani's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black2001gsr &raquo;</TD></TR><TR><TD CLASS="quote">I recently purchased my JDM carbon fiber window switches from kepani and installed them today.</TD></TR></TABLE>
i sold them? :shrugs: your install looks a1 steak sauce!
Old Aug 4, 2003 | 03:46 AM
$pecial K's Avatar
just wondering how much did u get them for?
Old Aug 4, 2003 | 03:50 AM
machgo5go's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">good job the detaled pics!!</TD></TR></TABLE>
I just dremel JDM Driver's Carbon plate until it fit the USDM switch and also drill an additional hole.
Old Aug 4, 2003 | 05:10 AM
TRuST's Avatar
Cool, thanks for the info. Too bad you couldn't do that same thing with a JDM center console ?
Old Aug 4, 2003 | 05:54 AM
Look at the Red/black pass on/off button. This is why you need to take the JDM button and install it onto the USDM box. Notice the big space left open because the USDM button doesn't match the JDM carbon piece.
Old Aug 4, 2003 | 05:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OutLaw R &raquo;</TD></TR><TR><TD CLASS="quote">Damn I didn't even know that the JDM's came with it.Looks pimp,good job!
If you're talking about the pass side vent, it doesn't come in carbon fiber.
I'm working on that piece now, I'll post pics
Modified by black2001gsr at 4:13 PM 8/4/2003
Old Aug 4, 2003 | 09:31 AM
machgo5go's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black2001gsr &raquo;</TD></TR><TR><TD CLASS="quote">Look at the Red/black pass on/off button. This is why you need to take the JDM button and install it onto the USDM box. Notice the big space left open because the USDM button doesn't match the JDM carbon piece.
Thanks for advice but I just bought the plates back then, no JDM switch included.
Old Aug 4, 2003 | 10:02 AM
Lucky-R's Avatar
this is the most thorough step-by-step install of these i've seen
did mine last year with my brother and i had to guestimate and dremel bit by bit until i could retro-fit my usdm switches onto the jdm plate...very happy with the result though.
your lesson would have helped. nice job-
Old Aug 4, 2003 | 04:28 PM
Thank you for the compliments. If anyone has any question please feel free to IM me
Old Aug 4, 2003 | 05:17 PM
twuelfing's Avatar
where do you buy these and how much?
Old Aug 4, 2003 | 05:29 PM
RickV's Avatar
Default Re: (zyg)
Damn, you guys don't get much in the USDM Type-R. This stuff is standard for the Australian version.
Old Aug 4, 2003 | 05:47 PM
Default Re: (zyg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyg &raquo;</TD></TR><TR><TD CLASS="quote">Nice plastic pieces!
Shouldn't this be in the appearance/cosmetic section? </TD></TR></TABLE>
It's here for the Type R owners And I got these for $45 shipped.
Old Aug 4, 2003 | 06:54 PM
Default Re: (zyg)
Thats nice.
Old Aug 4, 2003 | 06:59 PM
ZygSpeed's Avatar
Default Re: (black2001gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black2001gsr &raquo;</TD></TR><TR><TD CLASS="quote">Thats nice.</TD></TR></TABLE>
So, those make you faster?
Or, they keep people from stealing your car ... like the door lock elimination mod?
Yeah ... nice! LOL!
Old Aug 4, 2003 | 07:07 PM
Default Re: (zygspeed)
I never said that these parts were suppose to make my car faster. It's like you wanting to power coat your pipe.
Old Aug 4, 2003 | 07:12 PM
MugenizedR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah ... nice! LOL!</TD></TR></TABLE>
What's up with this crap? Leave this dude alone. He was nice enough to take his time to post the directions and pictures for everyone. If you dont like this post don't respond to it.
Old Aug 4, 2003 | 08:27 PM
Black R's Avatar
25 Year Member
Default Re: (zyg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyg &raquo;</TD></TR><TR><TD CLASS="quote">But I'm just .... not concerned with appearances.
OOoooooh?! .....what about that show hood on your kaa?
Nice writeup, nonetheless.
I'd like to "fix" the passenger's side vent too.....
Old Aug 4, 2003 | 11:17 PM
Seedc2's Avatar
Default Re: (Black R)
where did you get those peices?
Old Aug 4, 2003 | 11:47 PM
Spoond TEG's Avatar
Default Re: (kendogg)
Nice write up too bad for all the haters.
I just had a quick question though. Has anyon ever thought of actually using REAL carbon fiber. I mean the Carbon pattern is nice but I kinda like the look of REAL carbon fiber.
I purchased some carbon fiber fabric and have even contemplated over laying some items with REAL Carbon fiber. Not hating as I am sporting the Type R Carbon LOOK myself but seriously contemplating using REAL carbon Fiber.
Old Aug 5, 2003 | 05:51 AM
Default Re: (Spoond TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG &raquo;</TD></TR><TR><TD CLASS="quote">Nice write up too bad for all the haters.
I purchased some carbon fiber fabric and have even contemplated over laying some items with REAL Carbon fiber. Not hating as I am sporting the Type R Carbon LOOK myself but seriously contemplating using REAL carbon Fiber.</TD></TR></TABLE>
I have a friend you has a real carbon fiber dash kit. The pieces look nice. But the pieces are coated with resin.
Old Aug 5, 2003 | 09:36 AM
JDC2's Avatar
good write up. now if someone would do a write up like yours with folding mirrors.
