injectors?
would the dsm 450's be able to feed 15psi on a built h22a? if not, what about the rx7, are they 550's? if they can, where can i get a set? would they be albe to support me and will they be able to fit?
thanks
daniel
thanks
daniel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">would the dsm 450's be able to feed 15psi on a built h22a? if not, what about the rx7, are they 550's? if they can, where can i get a set? would they be albe to support me and will they be able to fit?
thanks
daniel</TD></TR></TABLE>
i doubt it... go with 860cc+ if your shooting for 500hp off a thristy H22
thanks
the 450 won't do for 15 PSI, you need go bigger. here you can use this to get a close idea at how big of injectors you need.
http://www.rceng.com/technical.htm#WORKSHEET
