Sway Bar Question
Old Aug 3, 2003 | 07:42 PM
B HATCH's Avatar
Default Sway Bar Question
I have a 93 Civic DX, so it has LCA's with no mounting holes. I have a Apex-I WS cat Back...and i want to put a Rear Sway bar...i would like to have a ITR size bar.
I would like to know who else has this exaust and which LCA did they put and which sway bar fit without problems....does the ITR LCA's move the track out? ( i thought it was wider track)
Can i use any 04-01 TEG LCA with A ITR bar?
Modified by T-Spec at 12:17 AM 8/4/2003
Old Aug 3, 2003 | 08:07 PM
B16b2b's Avatar
Default Re: Sway Bar Question (T-Spec)
use 94+ gsr rlca's. it shouldn't affect the "track."
Old Aug 3, 2003 | 08:11 PM
VX's Avatar
VX
Use any 94-01 Integra LCA's they have the mounting holes.
You can also use the ITR LCA's as well, but you will have to use an ITR rear shock assembly in conjunction w/ them.
Old Aug 13, 2003 | 07:48 AM
Kev95lx's Avatar
Default Re: Sway Bar Question (VX)
so if the car doesn't have a rear sway bar, the 94-01 'Teg LCA's are the way to go?
I've got to find out if the 95 Sedans had a rear sway bar..it's an LX..
and what about the use of a lower tie bar? I saw that Beaks has a kit that they sell that will enable you to continue to use one..
Old Aug 13, 2003 | 07:51 AM
Damon's Avatar
Lower Arm bars are overrated. The difference is transparent. get a bigger sway bar, and you will never notice a difference with or without the lower tie.
Old Aug 13, 2003 | 07:56 AM
Kev95lx's Avatar
Default Re: (Damon)
So a 22mm or 24 mm bar would be more than enough to make up the the lack of a tie bar i assume?
Also, anyone know if a 95 Civic LX (sedan) came with a rear sway bar?
Old Aug 13, 2003 | 08:04 AM
White Lightnin's Avatar
Default Re: (Kev95lx)
Just get the LCA's off a teg or civic that came with a rear swaybar. Then add the parts from the dealer and a BSQ kit. Works for me.
Old Aug 13, 2003 | 11:05 AM
Kev95lx's Avatar
Thanks for the info..
Old Aug 13, 2003 | 12:08 PM
tunes12's Avatar
you can also just get a progess 22mm bar which has brackets that come off the shocks, works excellent, no need for different lcas's. I love mine.
Old Aug 13, 2003 | 12:31 PM
Kev95lx's Avatar
Default Re: (tunes12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunes12 &raquo;</TD></TR><TR><TD CLASS="quote">you can also just get a progess 22mm bar which has brackets that come off the shocks, works excellent, no need for different lcas's. I love mine. </TD></TR></TABLE>
do you have a pict? I'm trying to imagine this...
Old Aug 13, 2003 | 01:20 PM
SloCivicHMM's Avatar
There is mine...its s 22m progress bar you asked for pics of....mounts to the strut assembly......good ****!!
Old Aug 13, 2003 | 03:43 PM
tunes12's Avatar
no I don't have a pic, but I think I have seen one on this board somewhere. It's an L-shaped bracket that attaches to the front side of the lower shock bolt. Here's a link to some other threads about it. Has pics too.
https://honda-tech.com/zerothread?id=477381
Modified by tunes12 at 7:59 PM 8/13/2003
Old Aug 13, 2003 | 08:20 PM
Kev95lx's Avatar
Thanks for the link. that helped alot.
Just one more question...progress makes a 22mm bar..and the OEM ITR bar is 22mm..why not just get an ITR bar..it's cheaper that the progress..?
Old Aug 13, 2003 | 08:47 PM
eg crunkmonster's Avatar
dont forget u need reinforcement for those sway bars or you might get subframe tearout.....beaks has a kit for that task
Old Aug 14, 2003 | 02:12 AM
Default Re: Sway Bar Question (eg cookiemonster)
yeah L brackets off the strut bolt is what the progress uses.....sorry I have no close up pics....
The JDM ITR bar is 23mm and Beaks sells a kit, 185-195 shipped for the ITR/Beaks kit for the rear for any EG....the progress bar is also around that price range and is 22mm, however attaches to stock LCA bolt holes, and "expands" further out to the strut....maybe more stability but I have no proof of that it just makes more sense....
Yeah any Sway bar that attaches like an oem bar you'd need reinforcement on the subframe to avoid rippage!!
Old Aug 14, 2003 | 02:34 AM
elwood's Avatar
Default Re: Sway Bar Question (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah any Sway bar that attaches like an oem bar you'd need reinforcement on the subframe to avoid rippage!!</TD></TR></TABLE>
Nope. The ITR bar is the only one that needs reinforcement. Don't be wasting
your money for a beaks kit on your gsr bar.
Old Aug 14, 2003 | 05:24 AM
tunes12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kev95lx &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the link. that helped alot.
Just one more question...progress makes a 22mm bar..and the OEM ITR bar is 22mm..why not just get an ITR bar..it's cheaper that the progress..?</TD></TR></TABLE>
Because you need to get integra lca's for the itr bar to bolt up to. With the progress you get brackets that can be used without getting new lca's.
For the progress bar, all I did was put the biggest washer I could on the backside of the subframe, never had any problems.
Old Aug 14, 2003 | 07:11 AM
Default Re: Sway Bar Question (d15dude)
well you are correct....any aftermarket beeefy bar!! 14mm won't rip ****!! I don't even deal with bars smaller than 22mm
Old Aug 14, 2003 | 08:11 AM
Kev95lx's Avatar
Ok..but on the Beak's site the say that their kit (using the OEM 22mm sway bar)
has the following applications
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
All rear anti-sway bar equipped models of the following:
'92-'95 Honda Civic EX sedan
'94-'97 Honda Civic del Sol VTEC
‘94-’01 Acura Integra RS, LS, GS, and GS-R
The "Quick-Swap" kit comes with all components necessary for installation on Integras or Civics that are equipped with a factory rear anti-sway bar. </TD></TR></TABLE>
So..in this case I'm assuming I can take the LCA's from a Civic Sedan and hook up the ITR rear sway bar.
Sorry ..but I'm trying to:
a) understand and make sure I do it right
b) get the proper parts..
Old Aug 14, 2003 | 10:42 AM
yes.....just check for the endlink holes...you're set!!
Old Aug 14, 2003 | 10:44 AM
Kev95lx's Avatar
Default Re: (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">yes.....just check for the endlink holes...you're set!!</TD></TR></TABLE>
Yup..this article proves it also:
http://hybrid2.honda-perf.org/tech/ITRon5G.html
Old Aug 15, 2003 | 04:24 AM
agent87's Avatar
Use a reinforcement kit made by Beaks or BSQ. Mounting it the way they did in that Hybrid article has resulted in subframe tearout for a lot of people.
And you've probably found out by now but to answer your older question, no, to my knowledge, the LX sedan did not come with a rear swaybar. The EX did though. Hope this helps.
B_CRUZ!
Jul 9, 2003 05:35 AM
Mr. Softee
Jun 25, 2002 03:01 PM
lopey
Jun 22, 2002 01:01 PM
RS_POWER
Jun 5, 2002 06:09 AM
01geeser
May 9, 2002 05:04 AM
