The different types of Prelude blocks
Ok i just want to know what type of engines are in the 4th and 5th generations of preludes. I know H the is the prelude motor and the xx numbers folowing it is the displacement, like H22A H23 H22A1 H22A4 i think that's them, but i would just like to know which ones are which like which are VTech and what generations you can find that motor and which would be the most powerful? Thanks alot.
first of all it is "VTEC".
H22A and H22A1 are closed deck blocks and are found in the 4th gen ludes 190HP.
H22A4 is open deck block and is found in the 5th gen lude 195HP to 200HP. there are actually two different H22A4 blocks (SH and Base) and the cams are different as well in the two engines.
Not sure which block was used in the Type S but it came with a pnp head atts and higher cr pistons was 220hp.
H22A6 is found in Accord Euro-R around 220HP.
H23 is found in the SI 4th gen lude non-VTEC 165hp.
I think this is the right info but if there are mistakes somebody please assist me.
You can save mucho amounts of time if you use the "Search Function".
oh and just to prevent to me being flammed for an obvious reason i have just read the Prelude Specifications and Stats thread
and it answered my questions
From what i've seen, there are at least 2 versions of the 2.3l:
* H23A1 = USDM
* H23A2 = Euro, given for 160hp
Not sure about which one is JDM.
(oops) and H22A5 is an Euro 5th gen Lude engine, it's given at 185hp @flywheel
* H23A1 = USDM
H22A JDM
H22A1 USDM
H22A2 185hp euro
H22A4 USDM
H22A5 185 (and 200 in 99>
euro
H22A6 Euro R
H22A7 Accord Type R euro
H23A1 USDM Prelude
H23A2 Euro Prelude
H23A3 Accord and Rover Euro
H22A1 USDM
H22A2 185hp euro
H22A4 USDM
euroH22A6 Euro R
H23A1 USDM Prelude
H23A2 Euro Prelude
MadCityLude
Sep 22, 2006 09:45 AM
