H22A 11.5:1 JE PISTON ?
Old Aug 3, 2003 | 05:40 PM
H22AJSPEC's Avatar
Default H22A 11.5:1 JE PISTON ?
I have a built h22 block and am going to run the je 11.5:1 pistons crower rods and valve train and pp head.My cams are stock will i have clearance problems?I have large injectors what else should i watch for or get for fuel?
Old Aug 3, 2003 | 06:12 PM
Mikeyslude's Avatar
Default Re: H22A 11.5:1 JE PISTON ? (H22AJSPEC)
you should sleeve the block if not already done.
Old Aug 3, 2003 | 06:51 PM
v4lu3s's Avatar
RTFM
Default Re: H22A 11.5:1 JE PISTON ? (Mikeyslude)
are you getting the JE ones designed for FRM sleeves or the off the sehlf ones? if they arent the special ones you need sleeves.
Old Aug 3, 2003 | 07:38 PM
H22AJSPEC's Avatar
Ya im sleaved. But what about injectors. and engine managment? Will my stock ecu P28 work o.k. ? Should i run a little retard or rich?
Old Aug 4, 2003 | 04:04 AM
Mikeyslude's Avatar
what's your power goal? I've got 550cc and will be running around 325 to 350whp. i figure around 300cc or a little higher should do you fine. I would look into Hondata or AEM for an EMS.
Old Aug 4, 2003 | 08:35 AM
v4lu3s's Avatar
RTFM
Default Re: (Mikeyslude)
stock obd1 injecor are 345cc as it is though...i would think at least 370s would be needed.
es_squared
Jan 10, 2007 07:58 AM
hondafiend
Dec 5, 2006 05:19 PM
2.2SICKLUDE
Sep 3, 2004 10:20 PM
NoLipRacen
Jan 29, 2004 12:45 PM
BUCKO5
May 16, 2003 01:51 PM
