High compression valve cover gasket...
Old Aug 7, 2001 | 11:37 PM
976's Avatar
976
New User
Default High compression valve cover gasket...
Worth it?
Copper or rubber?
Performance? - I know I won't be able to feel the slight gain, but will the engine even? Thanks.
Old Aug 8, 2001 | 01:49 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: High compression valve cover gasket... (prsi)
I run a Spoon 2 piece that is basically made the same as factory with very hig C/R no problem..but then again I have never had a problem with High Comp and factory gaskets
Old Aug 8, 2001 | 12:55 PM
jweller's Avatar
I assume you mean head gasket, since the valve cover doesn't effect compression ratio. It's probably not worth the trouble to pull the head off just to change it, but if you are pulling the head anyway... you won't notice much of a difference, I'd say maybe 5 - 10 HP at most.
Old Aug 8, 2001 | 01:29 PM
976's Avatar
976
New User
Default Re: High compression valve cover gasket... (jweller)
Yeah, I ment head gasket. 5 - 10 hp gain, I think that sounds worth it!?
Ah, I will have it installed when I have my new engine dropped in.
[Modified by prsi, 10:30 PM 8/8/2001]
Old Aug 8, 2001 | 04:02 PM
Tsunami's Avatar
Default Re: High compression valve cover gasket... (Teken)
Pass it around.
Old Aug 8, 2001 | 05:10 PM
fixhondas's Avatar
Default Re: High compression valve cover gasket... (Tsunami)
I use a copper valve cover gasket- I run 36 pounds of crankcase pressure- anyone know where I can get a Titanium PCV valve?
Old Aug 8, 2001 | 08:07 PM
Mr. Choi's Avatar
New User
Um 5-10 HP??? No... Keep smoking what ever your smoking... Better yet, give me some...
HAHAHA. not even worht the money for maybe, at most 1 HP gain. if you want to raise your commpression ratio, you will need a thiner head gasket. this is a useless mod unless you've blown a head gasket. until it "blows" leave it alone and save up for when it does go bad.
Old Aug 9, 2001 | 11:39 AM
D's Avatar
D
Default Re: High compression valve cover gasket... (fixhondas)
dude, i'll sell you a TI PCV..... it's from a JDM TYPE R.
Old Aug 9, 2001 | 02:46 PM
reefer_bob's Avatar
Default Re: High compression valve cover gasket... (D)
So what is the consensus here? I have a 2000 GSR with I/H/E, and want to do the following:
CTR Cams
Cam Gears
Valve Springs
TI Retainers
Mugen Head Gasket
ARP Head Studs
The head gasket claims to bump the CR by .4. I have to think this alone would give at least a couple HP's. I also want to up up the redline to 8400 to take advantage of the full strength of the cams. What's the easiest way to do this? I guess the VAFC is in order here too...
Reefer_Bob
Old Aug 9, 2001 | 08:11 PM
976's Avatar
976
New User
Default Re: High compression valve cover gasket... (reefer_bob)
I am getting a new engine soon, and I got to thinking since I will be getting a previous japanese used engine, I need new gaskets, why not performance. I just wanted to know if it would be worth it.
lll
Feb 16, 2007 03:30 PM
dohcteg
Dec 23, 2006 12:03 PM
sleepyIntegra
May 26, 2004 03:43 AM
JBBNJ609
Sep 21, 2003 09:16 PM
Qwikrex
Nov 19, 2002 05:02 PM
