drag intercooler mounting question
Does anyone have pics of how they mounted theirs? I searched and see that I will have to cut the bumper support and relocate the horns and bend the cooler lines out of the way. Just wanted to get some pics so i know what I need to do. I already have the bumper off and just need to mount the damn thing. Thanks guys.
shitty pic to get people to look.
here is a drag 2 prelude intercooler on my accord, i had brackets welded on. my PS cooler sits behind the bumper support.
Did you have to cut the bumper support? With preludes that whole bumper support comes out when you take the bumper out. Right now I am trying to figure where I should mount it. Again from what I read i will have to cut the bumper support and relocate the horn and cooler lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 »</TD></TR><TR><TD CLASS="quote">Did you have to cut the bumper support? With preludes that whole bumper support comes out when you take the bumper out. Right now I am trying to figure where I should mount it. Again from what I read i will have to cut the bumper support and relocate the horn and cooler lines. </TD></TR></TABLE>
I trimmed it a lil bit, but it is still there.
i'd like to see too . people from drag are absolutely no help, never respond to emails
do you have gen 4 kit for 5th gen lude?
if so, i'm about to mount mine. there is a hole above the power steering cooler line in the center . it mounts there. it is supposed to stand out enough to clear the ps lines but i dont think it will, will likely need a spacer or something to cushion it. also need to cut the hole bigger where the charge pipe needs to go through
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune »</TD></TR><TR><TD CLASS="quote">i'd like to see too . people from drag are absolutely no help, never respond to emails
if so, i'm about to mount mine. there is a hole above the power steering cooler line in the center . it mounts there. it is supposed to stand out enough to clear the ps lines but i dont think it will, will likely need a spacer or something to cushion it. also need to cut the hole bigger where the charge pipe needs to go through</TD></TR></TABLE>
Its for a drag 4 and it going into a 4th gen. But I think I have that hole too thats how come I kinda want to see how people mounted it and if they moved their horns and/or ps cooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopimp »</TD></TR><TR><TD CLASS="quote">The bracket for the PS cooler is bent straight and the cooler is moved to behind the hood latch support. The bumper support does not have to be cut.</TD></TR></TABLE>
Hey thanks for your help and the info you sent!!!
fastlude69
Jul 14, 2007 08:49 PM
-iLLuZioN-B18C1
Jul 31, 2003 10:47 PM
