da front seats in ef civic?
Old Aug 3, 2003 | 11:02 AM
Ronin Panda's Avatar
Default da front seats in ef civic?
will they work? what mods need to be done?
anyone do this?
thanks for the help
Old Aug 3, 2003 | 02:37 PM
Default Re: da front seats in ef civic? (Touge Panda)
nobody has done this?
come on guys
Old Aug 3, 2003 | 02:42 PM
fourthgenhatchB17's Avatar
Do a search...its been done many times before. I have a 89 hatch DX with 2nd gen teggy seats in it. I got the car with them already in there but i can tell u drilling is required.
Old Aug 7, 2003 | 09:56 AM
i searched with no real results...can someone please fill me in on what needs to be done and how hard it is to perform this..thanks
Old Aug 7, 2003 | 10:11 AM
Agent Daimon's Avatar
Default Re: (Touge Panda)
i ghetto rigged it..the rails dont match so u gotta switch them..i only have two screws holding down each seat. you just gotta be creative! sorry if this doesnt help.
Old Aug 7, 2003 | 10:23 AM
Default Re: (Agent Daimon)
haha thanks bro...atleast you tried...so you just put the stock civic rail on the da seat (the one rail that can be unbolted)...right? and have only the two bolts on one side of the seat holding it down?
anyone else?
Old Aug 7, 2003 | 12:23 PM
who has done this the right way and can help me out?
Old Aug 7, 2003 | 01:28 PM
5DegAdv's Avatar
I just put some integra seats in my car yesterday. The 2 outer tracks on each seat I swapped over to the teg seats, I left the inner tracks on and set the seats in the car. They lined up over the mounting holes but I definetly had to drill new holes in the tracks. I pin pointed where the holes should be, made a mark, pulled the seat back out then drilled the new holes. I put the seats back in and bolted them down. whole job took like 2 hours.
Old Aug 9, 2003 | 09:10 AM
Default Re: (jfoxmatt71)
uhh...its not working out as easy as you made it sound bro...the outer tracks on the integra seats has a little bracket on it that holds the seat back to the seat bottom..if i take off the outer brackets ..then the seat back will wobble around..i reallly need help with this...is there any other way(s) to do this? im having trouble.
damnit! this is pissing me off..i need these seats in my damn car...thanks for trying to help ..anyone else have this problem?
Old Aug 9, 2003 | 10:45 AM
Lo-Buck EF's Avatar
im tryin to fit dc2 seats in my ef and its now working eather. sux
Old Aug 9, 2003 | 11:10 AM
5DegAdv's Avatar
Are you sure, cause it was the inner brackets on mine that connected to the seat backing...it's the same bracket with the retractable seatbelts on them. I just took the teg seatbelts off, put my stock one on and re-drilled the holes to mount to the floor....worked perfect for me.
SMOOTHN
48
May 9, 2023 06:19 AM
HWKR3W
35
Nov 12, 2010 01:23 AM
akshn1
May 4, 2009 08:44 AM
dohdoh420
Feb 4, 2006 03:56 PM
superacecardriver
Oct 9, 2004 03:44 PM
