aftermarket head gasket?
Old Aug 3, 2003 | 10:27 AM
philafelman's Avatar
Default aftermarket head gasket?
has anyone here used any aftermarket headgaskets (mugen, spoon, etc.) to raise compression? is there any problems with them or pretty reliable. i want to get jdm type r pistons with a mugen headgasket on my gsr motor, do you think it would be a good idea??
Old Aug 3, 2003 | 10:42 AM
Heisdan's Avatar
bump for a good question looking for an answer to similar type of question
CTR pistons too high compression for a GSR motor? .. next in line is JDM type R pistons ..
What type Of Headgasket is best..
BUMP BUMP BUMP
Old Aug 3, 2003 | 10:53 AM
Xumarius's Avatar
Default Re: aftermarket head gasket? (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">has anyone here used any aftermarket headgaskets (mugen, spoon, etc.) to raise compression? is there any problems with them or pretty reliable. i want to get jdm type r pistons with a mugen headgasket on my gsr motor, do you think it would be a good idea??</TD></TR></TABLE>
I didn't know head gaskets raise compression on a car. Damn let me get one now!
Old Aug 3, 2003 | 11:07 AM
Default Re: aftermarket head gasket? (Xumarius)
i was just searching inlinefour.com, and i all i could find was spoon, mugen, and toda...is there any other reliable brands out there. i would think with jdm itr pistons, it would put my car at around 11.5:1 cr...and thats pretty much where i want to be, but i havent ever heard any feedback from somebody using this setup...theres gotta be someone out there.
Old Aug 3, 2003 | 12:33 PM
ttt
Old Aug 3, 2003 | 12:45 PM
Heisdan's Avatar
.. bump bump .. high compression headgaskets can raise ya .5 compression or so at most!! .. uhh
SOMEONE HAS TO HAVE THIS SETUP
Old Aug 3, 2003 | 01:25 PM
IN VTEC's Avatar
Default Re: (Heisdan)
Cometic makes headgaskets of differing thicknesses. http://www.cometic.com
Old Aug 3, 2003 | 01:30 PM
P1mpSlap's Avatar
I believe if your head isn't warped and the block is pretty even/smooth you wont have a problem with it.
There have been cases of failure of those headgaskets and it will seriously **** up the head and/or block.
Here's a pic of 1layer head gasket failure
not pretty
Old Aug 3, 2003 | 03:49 PM
Forgiven's Avatar
[QUOTE=Heisdan]bump for a good question looking for an answer to similar type of question
What type Of Headgasket is best.. [QUOTE=Heisdan]
12.042422511586593 with CTR's.
11.362493622638828 with JDM ITR's.
Both are with OEM head gasket. If you want to calculate your compression here's a link. http://www.c-speedracing.com/h...c.php
Old Aug 3, 2003 | 04:17 PM
NA gs-R 05 C
Guest
Posts: n/a
overall, they're reliable.
Old Aug 3, 2003 | 04:27 PM
TeamTooQuick's Avatar
Default Re: aftermarket head gasket? (NA gs-R 05 C)
i heard nothing but good things about them, all i heard that people suggest is to get some ARP head bolts and you'll be good....
Old Aug 4, 2003 | 06:23 AM
Heisdan's Avatar
so .. overall what is the highest compression somoen should go w/ pump gas.. 91-92 w/out tuning ..
and I'd be stuck tuning it right after I get these.. correct?
Old Aug 4, 2003 | 07:59 AM
Stewie's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">I believe if your head isn't warped and the block is pretty even/smooth you wont have a problem with it.
not pretty
Those are some huge intake valves! Stock?
Old Aug 4, 2003 | 07:14 PM
Default Re: (Mac8008)
so do you think a mugen or spoon headgasket (2 layer) would be a good idea with jdm itr slugs and a mild valvetrain (type r or skunk 1's)? am i ok with oem headbolts?
bulori
43
Sep 2, 2004 08:15 PM
ITR.#1446
Mar 22, 2004 01:43 AM
JunIntegra
14
Jan 10, 2004 02:19 PM
speedy-crx
Jan 20, 2003 02:14 AM
Stunna BEN
Dec 18, 2001 08:03 AM
