Questions about straight piping..
I have an exhaust leak from my flex pipe. Also i was told that my cat is breaking down and leaking as well.. i wanted to just buy a test pipe and a new flex pipe from accordingly done.com.. they seem to have great prices so no worries about that.
i do worry about my o2 sensor and how it would react to the piping. I assume it'd be well advised to have an o2 sensor bung installed on the test pipe but would i throw codes without the emissions restrictions that the cat offers?
Also about sound.. is it really true that the exhaust becomes noticably louder when you have no cat? I dunno how i feel about that.
Edit:: one thing i forgot- what size should i buy the pipe in? right now i have a thermal cat-back system (stealth) which i think is 2.25".. but i want this all to bolt up so should i stick with the 2.25"? Three flange bolts correct?
Thanks!
In Short:: Buying a test pipe. Will i throw CEL's w/ the o2 sensor installed on the pipe? What should i expect from installing the pipe?
Thanks!
4th gen?
I have a test pipe and throw no codes..... your O2 sensor is right before the cat correct? So the misssing cat would have no effect on O2 sensor readings.....also, I think the thermal is 2.5 inch, thats what mine is
and yeah, its a little louder......but not too bad
oh alright, i may have been mistaken wheni looked at the cat..i thought the o2 sensor was coming off it..but good, as long as i throw no codes. then i'm all set. i have a 4th gen so.. if thats how it works out..good. thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX »</TD></TR><TR><TD CLASS="quote">so does that mean if you get an aftermarket header you won't have an o2 sensor?</TD></TR></TABLE>
most aftermarket headers have a bong so that you can still plug in your o2 sensor, if not you would probably get a cel code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A »</TD></TR><TR><TD CLASS="quote">
most aftermarket headers have a bong so that you can still plug in your o2 sensor, if not you would probably get a cel code.</TD></TR></TABLE>
haha..yea i think the term is..bung. but yeah that's right.
