Energy Supsension Motor Mount Inserts
Old Aug 3, 2003 | 09:36 AM
JUN JDM's Avatar
Default Energy Supsension Motor Mount Inserts
Who has these?...Tell if you like them?...and how long did it take you to install them?.....was it hard?......do they work well?......like no car hoping?...and i guy i met told me that...when you just sitting at a light or your at a complete stop w/ your A/C on.....you feel the motor shaking...or rattling...is that true?
Becuase i'm planning on getting some...b/c when i go to the track...i get mad car hop!!!
Old Aug 3, 2003 | 09:47 AM
CHILIBEANZ's Avatar
i don't have them but if u do a search on clubrsx you'll find a ton of related threads. i heard vibration is a ****.
Old Aug 3, 2003 | 09:56 AM
GoodKnight's Avatar
Default Re: Energy Supsension Motor Mount Inserts (JUN JDM)
Just put mine in yesterday. If you have a bunch of motor mods, you'll want these. I was at the track and could feel my motor flexing a LOT when shifting. Decided to finally install these, and noticed my front mount was torn on the inside. It's not a bad install, just time consuming, esp if u dont know what to do. But after knowing what to do, I could probably do this within an hour or two. Took me about 4 hours bc 2 bolts were causing me problems.
Old Aug 3, 2003 | 12:53 PM
1EuroEp's Avatar
Default Re: Energy Supsension Motor Mount Inserts (GoodKnight)
a great mod to have, wheel hop is no longer an issue. As Goodknight said the install is not all that difficult. I would however rec. having someone to help out, esp. while rocking the engine to insert the front.
I found it helpful to use a little lube when inserting the back mount with the inserts into the bracket. it'll save you time and energy.
David
Old Aug 3, 2003 | 03:58 PM
JUN JDM's Avatar
Default Re: (p220)
where on clubrsx?
Old Aug 4, 2003 | 01:28 AM
J2turbo21's Avatar
Default Re: (racerdc5)
Naw you wont have to replace it just put the insert in and you'll be fine.
Tony Starks
15
Mar 10, 2003 11:43 AM
ill phil
Jan 13, 2003 10:15 PM
gsrstyle
Dec 23, 2002 02:27 AM
dynamo
Aug 27, 2002 01:40 PM
Stock R
Apr 11, 2002 01:17 PM
