very bad vibration please help and please read
Old Aug 3, 2003 | 07:41 AM
1stealthls's Avatar
Default very bad vibration please help and please read
have a 90 crx w/b16a
i replaced the axle cuz the boot was torn and started makin some noises
well after i did that i had a major shaking with the left front(side i replaced)
so i figured auto zone gave me a junk one well 4 axles later same problem .....i have checked everything .......would the intermidate shaft cause this also it only does it when i turn right or get on it hard.....i have had the wheel off to check where it is comin from still stumped .......could it be somethin w/ the tranny?????or do i have to take the snap ring off of the axle or what????this is getting real stressfull i need it fixed by monday........i checked everything ...brakes....wheel bearing....ball joints....tie rod ends.....please help any suggestions would be great
thanx ahead of time
_______
Old Aug 3, 2003 | 12:51 PM
mntuner2's Avatar
Default Re: very bad vibration please help and please read (1stealthls)
sometimes honda axles can be tricky to get apart or put back together. Usually a clip will get damaged or bind up a little while removing. I would say take it back apart and inspect all the splines and make sure everything looks clean and unscratched/gouged. If anything looks some what jacked, hit the splines with some machinists files so the axle can be installed in the hub and trans without interference(lube lube lube her up!). Then take out the just tested piece and install a fresh retaining spring. This was long and not thoughout, im sure I misssed something and im sure you allready did all this but its worth a shot. If dirt or anything gets between the axle from not properly mating to the hub(same with the clip/axle mating into the tranny), it will literally shorten the overall space the axle has to move= less race for bearing to move in...binding=bad
Old Aug 3, 2003 | 03:20 PM
sir91's Avatar
You defiantely need to take off the snap ring on the axle. I woud then check your rotors. the rotor may be warped. Also what mount kit are you using? Maybe the postion the motor sits is making the axle bind. Has you car been crashed? you may have one of the suspension pieces bent slightly or even the frame. Hope you find it. If you do post it for future ref.
Old Aug 3, 2003 | 04:56 PM
shatshadarach's Avatar
Default Re: very bad vibration please help and please read (sir91)
I got that in my 90 Si w/B16A, hasport mounts...but sometimes it goes away, and sometimes it's really bad...I've also started getting a rattle (like a soup can full of rocks) out of the front right whenever I turn left...the axles have only been in since the swap (like 7 months use!!)...I guess this info doesn't really help you, sorry
Old Aug 3, 2003 | 05:26 PM
1stealthls's Avatar
Default Re: very bad vibration please help and please read (shatshadarach)
disregard
Old Aug 3, 2003 | 09:44 PM
LD_EGSICK's Avatar
make sure you have your car idle at 750 rpms
GeezerGSR
May 29, 2008 06:43 PM
KING_LIAN
Oct 3, 2007 07:35 AM
youngvedder
May 30, 2004 02:01 PM
xhatchracerx
Oct 23, 2003 01:05 PM
1stealthls
Aug 8, 2003 06:30 PM
