Question about swap 99 si motor into 92 hb civic DX?
Old Aug 3, 2003 | 06:55 AM
esoterEK..'s Avatar
Default Question about swap 99 si motor into 92 hb civic DX?
Have any of you guys out there done this swap before and what other stuff do i need in order to make my 92 civic work with the OBD II si engine...any help will be appreciated...thanks...? List all the stuff i need......?
Modified by EGkwazhimoto at 9:21 AM 8/3/2003
Old Aug 3, 2003 | 09:58 PM
esoterEK..'s Avatar
Default Re: Question about swap 99 si motor into 92 hb civic DX? (EGkwazhimoto)
ttt
Old Aug 4, 2003 | 02:17 AM
drevinder's Avatar
u can use all ur motormounts except for the a/c bracket(front driver side) use the si one si shift linkage , keep ur wiring harness , si half shafts, ofcourse the obd 1 comp if not use the si one with the conversion harness, dammmmmmm i can't remember what tranny mount i used i will fing out if u want i just took my b-16 out of my vx last weekend tha's about all i can think of right now
Old Aug 4, 2003 | 04:05 AM
VTECVillain's Avatar
Default Re: (drevinder)
Actually the mounts needed to put the 99 Si motor into a 92-95 Civic are: 94-01 Integra driver's side mount + bracket, 94-01 Integra rear bracket, reuse stock upper tranny mount, Del Sol A/C bracket (to keep A/C), and a 94-01 Integra front tranny bracket.
The Si intermediate shaft, axles, and shift linkage will work or 94-01 Integra parts will also work. I would suggest using an OBD1 chipped P28 or P30 ECU to keep wiring at a minimum.
Old Aug 4, 2003 | 07:20 AM
esoterEK..'s Avatar
Default Re: (VTECVillain)
thanks...guys for all the info.... i think im going to buy a p30 ecu and instead of the conversion harness for the 99 si ecu cause it cost about the same....haha....and do you guys know if there any difference between a JDM p30 ecu and USDM p30.................thanks...
curioso
Nov 12, 2009 08:23 PM
slopoke1989
22
Jul 23, 2009 08:53 PM
Civichatch972
Oct 6, 2002 01:42 PM
