16inch DRAG tires? HELP!
I want to upgrade the brakes on my Turbo ITR for track racing, but I wonder if I can do DRAG racing with an 16inch rim, cause a 15incher will not fit over the caliper. Where to find an 16inch DRAG slick with about 610 mm diameter and 230mm contact path?
there isn't **** for 16 inch rims for us import boys.
no slicks, drag radials were discontinued (unless you want to run a 26" tall tire for a domestic)
BFG makes a 255 wide drag radial, but thats if you hate a good turning radius
Nitto makes a 245 drag radial but its meant for a mustang and would be too tall for you.
motormatrix is running the 255 BFG but hes hardcore drag racer like that.
your kinda **** out of luck unless someone has something I haven't seen, I am actually planning on going to a 15" rim so I can get a drag radial.
gl man
gl man
well with drag radials most drive them on the street, so you might if you were in that position.
if you arent then slap some 255 BFG's on there and call it a day, b/c you won't find slicks for your car in 16"
