want to do a compression test on my STD need help
i compression @ a high for each cylinder should be 158 psi and no less than 128 psi and no more than 28 psi difference between all the cylinders. Any other ?'s give me a call 540-457-6058
thank you very much <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cvchb »</TD></TR><TR><TD CLASS="quote">i compression @ a high for each cylinder should be 158 psi and no less than 128 psi and no more than 28 psi difference between all the cylinders. Any other ?'s give me a call 540-457-6058</TD></TR></TABLE>
thank you very much
thank you very much
brent_G
Oct 12, 2003 12:15 AM
