Help: Installing back Stock GSR Manifold
Old Aug 2, 2003 | 05:59 PM
TroyL's Avatar
Default Help: Installing back Stock GSR Manifold
Hi, I am pulling off my Victor X Manifold off my GSR and going back to stock to sell my car. Its a 98 GSR. I have a couple questions on where some of the hoses and stuff go.
1st- Where does the red PCV Valve hose run to.
2nd- There is a big sensor on top of the manifold that sits right in the middle that has two fittings that come off of it, where do they go?
3rd- There is a big canister under the battery which I think is called the EVAP canister. It has two fittings on it. Where does the top middle one go to.
4th- Then there is a fitting in between the TPS Sensor and the Map Sensor on the edge of the throttle body and the manifold that faces up toward the firewall and the hood. Where does that go?
5th- Finally underneath the manifold almost directly in the middle there is a fitting where does that go to?
If anyone could help me or look at there car and let me know where these things go I would be very appreciative. Thanks
Old Aug 3, 2003 | 06:53 AM
TroyL's Avatar
Default Re: Help: Installing back Stock GSR Manifold (TroyL)
anyone?
Old Aug 3, 2003 | 08:05 AM
IN VTEC's Avatar
A picture is worth 1.12 billion words.
Old Aug 3, 2003 | 08:08 AM
IN VTEC's Avatar
Default Re: Help: Installing back Stock GSR Manifold (IN VTEC)
1st and 5th probably go together.
Black box w/ PCV valve sitting on top of it -hose-> nipple on bottom of manifold.
Old Aug 3, 2003 | 08:15 PM
TroyL's Avatar
Thank you so much. That really helped.
VTEC_Du_Ma_Mai
Dec 28, 2007 12:37 PM
NguyenDC2
Dec 12, 2007 01:51 PM
playahwitgame
Aug 8, 2006 09:04 AM
oblique
Sep 14, 2004 03:44 AM
