Smoke filled exaust
Old Aug 2, 2003 | 04:55 PM
4dohs4mohoes's Avatar
Default Smoke filled exaust
I've noticed that every time the car is sfifting gears or being pushed, it blows excessive some out the tail pipe. It smells like oil but, but I;ts not blue. What could it be. The motor is a ls/vtec with Itr pistons, Total set rings, gude cams, mild P and P, Itr valve train.
Old Aug 2, 2003 | 07:23 PM
Keel's Avatar
Default Re: Smoke filled exaust (lilgreenhonda)
If the smoke is white check your coolant level if its low its probably a blown head gasket.
I just had that problem.
Old Aug 2, 2003 | 08:22 PM
Default Re: Smoke filled exaust (Keel)
just changed it
Old Aug 2, 2003 | 08:45 PM
skunkintegra's Avatar
it's oil.....
improper seating of the rings???
Old Aug 2, 2003 | 09:38 PM
BlackB18CTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilgreenhonda &raquo;</TD></TR><TR><TD CLASS="quote">I've noticed that every time the car is sfifting gears or being pushed, it blows excessive some out the tail pipe. It smells like oil but, but I;ts not blue. What could it be. The motor is a ls/vtec with Itr pistons, Total set rings, gude cams, mild P and P, Itr valve train.</TD></TR></TABLE>
Last time i checked.... burnt oil is black....
Old Aug 2, 2003 | 09:45 PM
AWDxBOOST's Avatar
Default Re: Smoke filled exaust (BlackB18CTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Last time i checked.... burnt oil is black....</TD></TR></TABLE>
yep...u runnin ls/vtec and dont know that?
Old Aug 3, 2003 | 09:53 AM
SIK IN DA HED's Avatar
New User
no.. burnt oil burns blue.
it looks white... but if you look at it closely... or look at it while the smoke blows towards the front of the car... its really blue.
Old Aug 4, 2003 | 08:35 PM
Default Re: Smoke filled exaust (SIK IN DA HED)
yeah well when i pused like sideways on the pistons 1 and 4 kinda moved less than 1/8th inch, and sludge (oil) seeped upwards
Old Aug 4, 2003 | 08:39 PM
StyleTEG's Avatar
black is usually fuel.
How has your car been tuned? Is it running really rich?
Try doing a WOT run and shutting the car down immediately. Don't coast, let the rpms drop, etc... Just kill it and pull over.
Take out the spark plugs and see if they are covered in carbon.
Teggymaniac379
Aug 24, 2017 05:47 AM
ITR32
Feb 10, 2008 07:23 PM
viprcr1
Mar 5, 2004 02:32 PM
jdm-spec-eg
May 25, 2002 07:34 PM
