**Little help with my ZEX install**
The directions say to connect the regulator hose barb on the NMU to the FPR's vacuum fittings. How do I tell where the vacuum fitting is on the FPR? It then says to connect the intake hose barb on the NMU to an unused vacuum fitting coming off the intake manifold plenum. I checked my intake mani and I couldn't find an unused vacuum fitting. Any advice would be appreciated, thanks.
BTW, if someone has a picture of where the FPR is located on a B16a that would be really appreciated because Im a little unsure as to whether or not Im getting it confused with the FMU or not. Thanks again.
I've installed the zex kit on my car before. here's how its set it up.
top hose from the fpr goes to the nmu i think its say regulator or something.
hose from the nmu that says intake goes to the intake (where u took off the fpr vaccum hose.)
so the nmu connects between your fpr and intake.
hope that clears it up.
Full Race A6
Aug 1, 2004 09:08 PM
