Can somone PLEASE tell me what these wires do
Old Aug 2, 2003 | 09:16 AM
Nerv2g's Avatar
Default Can somone PLEASE tell me what these wires do
I am using a GSR wiring harness on my ITR swap into a 92 VX. I have these extra wires under the distributor and I am wondering what they do. There is no place for them to plug into and I am curious to know what they do. Thanks for the help
Old Aug 2, 2003 | 09:41 AM
Nerv2g's Avatar
Default Re: Can somone PLEASE tell me what these wires do (Nerv2g)
Oops forgot to tell you guys the colors of the wires. A green wire with a black stripe and a red wire with a yellow stripe. Once again thanks for the help.
Old Aug 3, 2003 | 12:31 AM
MPower332TI's Avatar
Man you sure are hairy..haha. But anyways just thinking of the top of my head if you say there is no where for it to plug into it should be the plug for the iabs on the GSR intake manifold so you wont need it. As long as you dont have any plugs not plugged in on the motor than yes this is the iabs.
Old Aug 3, 2003 | 01:03 AM
Nerv2g's Avatar
Default Re: Can somone PLEASE tell me what these wires do (jDmDxTuRd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd &raquo;</TD></TR><TR><TD CLASS="quote">Man you sure are hairy..haha. </TD></TR></TABLE>
It's keep me warm in the winter Thanks for the reply man what does "iabs" stand for? Thanks again
Ian
Old Aug 3, 2003 | 01:15 AM
Kamin's Avatar
ill confirm, those are for IAB's as long as everything else is plugged in.
and i dont know what IAB stands for but its the secondary butterflies on the GSR manifold.
Old Aug 3, 2003 | 05:09 AM
Nerv2g's Avatar
Default Re: Can somone PLEASE tell me what these wires do (Kamin)
Thanks for the reply. I was worried that it had to be grounded. Thanks again for you help
Old Aug 3, 2003 | 09:04 AM
Trey's Avatar
25 Year Member
Well first off, does the car crank and idle correctly? Are there any check engine codes?
If all those are fine, don't worry about it but TAPE UP THE WIRES!!!
Old Aug 4, 2003 | 09:33 PM
Nerv2g's Avatar
Default Re: Can somone PLEASE tell me what these wires do (Trey)
Ok the car does turn over, but I have a CEL for ECT sensor. I reset the ecu checked the grounds and everything "looked " ok. I started up the car and the idle was perfect. Maybe 2 minutes later I heard that the idle increased and the CEL came back on. I did not know if the CEL was related to those 2 wires. I had the wires taped up but I untaped them and was trying to fin out if they had to be grounded. Thanks again for all the help
Old Aug 6, 2003 | 07:19 AM
Nerv2g's Avatar
C'mon guys I need your help
Old Aug 6, 2003 | 11:56 AM
kenji's Avatar
Those wires are NOT for the IAB. The wire colors should have made it clear that those wires are not for the IAB. BTW, IAB is an acronym for Intake Air Bypass.
You mentioned that you are throwing a code for the ECT (code 6).
If memory serves me correctly, those wires are for the ECT sensor on the side of the head. What are the wire colors for the plug that is plugged into the ECT sensor at this time?
-kenji
Old Aug 6, 2003 | 12:25 PM
Nerv2g's Avatar
Default Re: Can somone PLEASE tell me what these wires do (kenji)
I can't remember I am away from home for the next 3 weeks. If those are the wires for the Ect sensor shouldn't they have a plug around them? Thanks for the reply. Gotta get this car on the road so I could test out that ecu
Old Aug 7, 2003 | 07:36 AM
Nerv2g's Avatar
Can anyone Confirm what Kenji said? Thanks
Old Aug 7, 2003 | 08:02 AM
CanuckCRX's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenji &raquo;</TD></TR><TR><TD CLASS="quote">Those wires are NOT for the IAB. The wire colors should have made it clear that those wires are not for the IAB. BTW, IAB is an acronym for Intake Air Bypass.
-kenji
Old Aug 7, 2003 | 09:41 AM
Nerv2g's Avatar
Default Re: Can somone PLEASE tell me what these wires do (CanuckCRX)
Thank alot guys. This means I a supreme dumb *** I just never thought that they plugged into the ect sensor because the was no clip and the wires were short of the ect. Thank alot
Old Aug 7, 2003 | 12:39 PM
Eibach95Civic's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerv2g &raquo;</TD></TR><TR><TD CLASS="quote">This means I a supreme dumb *** </TD></TR></TABLE> isn't that a #9 at the taco bell menu?
KDvtec5757
Jul 13, 2009 04:49 PM
Nicks95GSR
Jul 19, 2008 10:24 AM
i_kick_turtles
May 27, 2007 09:54 PM
Hcivic88
16
Mar 7, 2004 12:51 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
