Jun transmission parts...
Okay... the old clutch flywheel have to go! it's gone from slipping to sudden moments uf tire chirping grip(I barely have enough power to chirp the tires!) I'm an all motor kind of guy, so I'm looking for a lightweight flywheel lightest I've found is JUNs 10lb unit, and I like the idea of matching components connecting the engine and tranny so... anyone know anything about the JUN clutch? All I know is it seems to be a 80mm Pressure 600kg.... whatever that means. Seriously though is it worth it? Their prices are high, but their reputation is good, and my baby only gets the best!
i went w/cm 10 lb flywheel like 3 years ago, and it works great. i just reacently went w/act clutch over my cm, and the combo is outstanding.
i used to go w/1 name on things, but i realized, where 1 company may be the best, another company may be the best at another part.
Jun's a 1 piece, so when it wears you'll have to spend another $500.. Also, the teeth are not ..erm.. bevelled? yah... so I hear it makes noise.
Fidanza makes an 8lbs, bevelled, and you replace the surface plate when it wears. A lot cheaper, and you can get it for $240 shipped.
http://honda.hybrids.jp/au02/clutch/
http://cgi.ebay.com/ebaymotors...33732
WVTURBOCRX
Jan 2, 2005 04:55 PM
