Throwing code 16 after MPFI swap..need help ASAP
Just done the DPFI to MPFI swap...car started right up but had a rough idle.Then I turn it off and restart it,and it dies and gives me a code 16 (fuel injector)and refuses to start back up..All wires are soldered,heat shrinked,and taped.Do you have to combine the 2 yellow/black wires from the primary and secondary injectors off the old DPFI and run them to your resistor box?I have one fat yellow/ black wire near the connector on the drivers shock tower tied into my yellow wire for the resistor box.Please help...I dont want to walk to work!
Glenn
Glenn
both wires ylw/blk from the dpfi harness need to be put together as one, then connect that to the resis. box
Thanks for the help!I wired the two yellow/black wires from the old dual point injectors to the resistor box and it fired right up.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subgeniusdude »</TD></TR><TR><TD CLASS="quote">Thanks for the help!I wired the two yellow/black wires from the old dual point injectors to the resistor box and it fired right up.
Glenn</TD></TR></TABLE>
