Installing head
Old Aug 1, 2003 | 10:00 PM
hatch4raceb16's Avatar
Default Installing head
ok, i just had my head rebuilt and i got titanium retainers , i had type r springs, and i have type r cams. I am giong to put my head back on, what is the trick to installing the head? Isn't there a pattern i follow in tightening head studs onto new headgasket. and waht is the torque spec for them? Also, what is the torque spec for the cam holder pieces and all taht? Help would me awesome guys, goin to put head back on sunday, thanks.
Old Aug 1, 2003 | 10:12 PM
slowdx's Avatar
Default Re: Installing head (hatch4raceb16)
get a helms manual it will tell you everything you need to know
Old Aug 1, 2003 | 10:15 PM
porsche997dc2's Avatar
Default Re: Installing head (slowdx)
you just miss the helm's manual download.
Go eg forum
Modified by porsche997 at 11:30 PM 8/1/2003
Old Aug 1, 2003 | 10:34 PM
RICE POLICE SIP's Avatar
Default Re: Installing head (porsche997)
it would be easier to show you in a pic. then tell you .....
Old Aug 2, 2003 | 01:07 AM
xteg95's Avatar
Default Re: Installing head (92boostn'hatch)
i think torque specs are 63 ft/lbs for headbolts and 72in/lbs for cam journals...like everyone else says get a manual of some sort so you have a picture and know the correct tightening sequence.
Old Aug 3, 2003 | 05:45 PM
Default Re: Installing head (xteg01)
i cant afford a manual right now, do u know if those specs are correct, and do i need specs for any other bolts in there?/ please help
Old Aug 4, 2003 | 07:33 AM
BUMP BUMP <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch4raceb16 &raquo;</TD></TR><TR><TD CLASS="quote">i cant afford a manual right now, do u know if those specs are correct, and do i need specs for any other bolts in there?/ please help </TD></TR></TABLE>
Old Aug 4, 2003 | 07:48 AM
irev210's Avatar
if u can afford to put new type R springs and titanium retainers on ur head... INVEST in a helms manual
Old Aug 4, 2003 | 08:11 AM
Default Re: Installing head (irev210)
NO, actually i cant right now and i need to put my head back on, so if someone could please actually help instead of be an *** and just write buy a manuel it would be great. All i want is the TWO specs, someone has to be nice out there, so please help me out. THANKS
Old Aug 4, 2003 | 09:13 AM
fox297's Avatar
I feel you man! Here's the bolt pattern:
8 6 2 4 10
9 3 1 5 7
Tighten the cylinder head bolts in a series of steps, increasing about 5-10 ft-lb each cycle.
I don't have the torque specs for the Vtec head, but for the LS head, it's 61 ft-lb for head-bolts and 7ft-lb for the cam-bolts. I think vtec head require a little higher torque.
0ne-Cam
Apr 6, 2009 06:30 PM
d16civic111
Jul 16, 2006 08:11 PM
egvtec
Feb 7, 2006 12:08 PM
deca
Dec 29, 2004 03:18 AM
