Replaced ignition rotor, now problems
Old Aug 1, 2003 | 09:39 PM
Bspec18's Avatar
Default Replaced ignition rotor, now problems
Well i finally decided to replace my ignition rotor i've had the stock one for like 74,000 miles now. I was hoping that my old rotor was really bad so that would explain the poor performance my car has had. After alot of tugging I put a new one in. I start my car, and it wouldn't turn over so I open the cap up wiggled a couple of wires and put it all back and tried again. It started But the car was bogging alot, i took it down the street and it felt like it was gonna turn off. I opened the hood and i smelled somthing burning possibly the WD-40 i sprayed trying to remove the old rotor i only put a little though just to loosen it up.
So Now im trying to figure why's its bogging way more now ? I have a MSD CAP and Blaster2 Coil. Can anyone point something i should be lookin for ?
Old Aug 1, 2003 | 09:45 PM
porsche997dc2's Avatar
Default Re: Replaced ignition rotor, now problems (Bspec18)
check you plugs, distributor cap contact point, rotor, distributor wires, timing.
Old Aug 1, 2003 | 09:56 PM
Bspec18's Avatar
Default Re: Replaced ignition rotor, now problems (porsche997)
yea i'll check the timing as soon as i get access to a timing light. The Cap is about a year old. I'm thinking possible Distibutor wires since my friend accidently cut them when he was looking for a Tach signal. i'll double check those plugs. The rotor is new so i doubt its that
Thanx
angie1977
Oct 4, 2006 07:19 AM
pdc125
May 15, 2005 02:26 AM
sodacan33
Jun 17, 2004 06:53 PM
absolutgsr
May 28, 2002 11:53 PM
