My steering wheel is shaking like crazy!!!!!!!!!!
Old Aug 1, 2003 | 07:58 PM
GSR-T-'s Avatar
Default My steering wheel is shaking like crazy!!!!!!!!!!
When Im driving my steering wheels kinda jerks back and forth(especially at low speeds) and when I turn the steering wheel it doesnt turn as sharp as it used to........I know its not my brakes or alignment.......
Old Aug 1, 2003 | 08:15 PM
f1uxx's Avatar
did you ever get a flat tire or something and fill it ?
Old Aug 1, 2003 | 08:21 PM
The-LS's Avatar
Default Re: My steering wheel is shaking like crazy!!!!!!!!!! (GSR-T-)
how low is "low speeds", tires balanced? Tread wear even?
Old Aug 1, 2003 | 08:31 PM
GSR-T-'s Avatar
never got a flat tire...tires are fine...low speeds are like under 20mph
Old Aug 1, 2003 | 08:33 PM
au-gsr's Avatar
well tell it to stop
Old Aug 1, 2003 | 08:38 PM
GSR-T-'s Avatar
ha yeah I wish
Old Aug 1, 2003 | 08:46 PM
98integraLS's Avatar
sounds obvious, but did u check the lugnuts?
Old Aug 1, 2003 | 08:55 PM
GSR-T-'s Avatar
yep there all tight
Old Aug 1, 2003 | 08:59 PM
GSR-T-'s Avatar
Id almost say that this problem started a few days ago and has progressively gotten worse....another thing is that when im driving on a slanted road the car will pull hard to the one side
Old Aug 1, 2003 | 10:08 PM
cccccccc's Avatar
wheels balanced?
Old Aug 1, 2003 | 10:55 PM
NONVTECNAINTEGRA's Avatar
Default Re: (GSR-T-)
i know a kid with a pt cruiser that has the same problem, he hit a BIG *** ROCK and the alignment is off on one wheel only, and sway bar or somethin was bent to crap ... good luck
Old Aug 2, 2003 | 09:18 AM
Sukebei Oni's Avatar
have you tried yelling at it. that what my brother does when the computer freezes.
but you may want to take a look at the car from underneath. look at all the steering parts like axel, tierodend, sway bar, steering rack, see if any thing looks bent. check your power steering fluid. you could also try to jack up the front wheels buy the lower control arm, that way the weight is still on the suspension. then try to shake the front wheel thats off the ground left to right and feel for something loose. or maybe even try rotating the tires. see if that makes a difference.
Old Aug 2, 2003 | 09:54 AM
rusteds2k's Avatar
Default Re: My steering wheel is shaking like crazy!!!!!!!!!! (Sukebei Oni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni &raquo;</TD></TR><TR><TD CLASS="quote">have you tried yelling at it. that what my brother does when the computer freezes.
.</TD></TR></TABLE>
I do the same thing. I swear it works.
anyways, i think you need to get an enlightment (sp)
Old Aug 2, 2003 | 10:03 AM
Nyc y0!!!'s Avatar
check your steering mechanism
Old Aug 2, 2003 | 10:11 AM
NeoGSR's Avatar
Default Re: My steering wheel is shaking like crazy!!!!!!!!!! (Nyc y0!!!)
sounds like a tie rod to me......cheap fix if that's the case.....
Old Aug 2, 2003 | 12:39 PM
sPaRk'iT's Avatar
try checking your axles
Old Aug 2, 2003 | 01:52 PM
Hites
Guest
Posts: n/a
Default Re: My steering wheel is shaking like crazy!!!!!!!!!! (sPaRk'iT)
is there small animal of some sort living under your hood? i had a small demonic monkey in my engine bay that caused a LOT of problems. i should have known that was bad mod in the first place! too bad that i miss him now .
Old Aug 2, 2003 | 06:11 PM
GSR-T-'s Avatar
I figured it out guys.....one of my tires had a blown belt so I just put it on the back for now....now everything is straight....thanks
Old Aug 4, 2003 | 11:58 AM
Digit's Avatar
what if the tires didnt wear evenly, what are your options?
i rotated mine recently and noticed that they wore a bit slanted
Old Aug 4, 2003 | 12:08 PM
Spoond TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-T- &raquo;</TD></TR><TR><TD CLASS="quote">I figured it out guys.....one of my tires had a blown belt so I just put it on the back for now....now everything is straight....thanks</TD></TR></TABLE>
SAY WHAT??? Your Tire had a Blown BELT???
Old Aug 4, 2003 | 01:12 PM
Hites
Guest
Posts: n/a
Default Re: (Spoond TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG &raquo;</TD></TR><TR><TD CLASS="quote">
SAY WHAT??? Your Tire had a Blown BELT???</TD></TR></TABLE>
hmmm... i dont know of any modern cars that have their wheels belt driven. must be a highly modded teg .
Old Aug 4, 2003 | 01:16 PM
Chris's Avatar
If it wobbles worst under exceleration, then you may need new axles.
I recently had a car do that, and NOT show the typical signs of wear.. (like the CLICKING)
Old Aug 4, 2003 | 01:17 PM
Chris's Avatar
oops.. Cool.
Get new tires man... warranty maybe?
Old Aug 4, 2003 | 01:41 PM
bps2799's Avatar
Ever heard the term "blowout"?
I hope so, because that's what you'll be having shortly.
Old Aug 5, 2003 | 09:31 AM
NeoGSR's Avatar
Default Re: (Hites)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm... i dont know of any modern cars that have their wheels belt driven. must be a highly modded teg .</TD></TR></TABLE>
how about a steel belted radial tire, just like the ones you're driving on???
95C0upe
18
Oct 28, 2008 06:30 PM
h22pwr
Apr 12, 2006 06:46 AM
canadianSIR-G
Nov 9, 2005 10:27 PM
Weapon_R
Feb 25, 2005 11:09 PM
Wicker Man
Apr 15, 2004 08:17 PM
