DC5 and EP comparisons
Old Aug 1, 2003 | 03:45 PM
Aiyoko Turbo's Avatar
Default DC5 and EP comparisons
Can someone please tell me some stuff about the DC5 and EP?
Not just stuff, but like base HP, 1/4 mile times, etc.
Thanx.
Old Aug 2, 2003 | 12:52 AM
f1nal zeros's Avatar
This have been covered many times and a search would have been easier but oh well **** happens and we all get lazy.
Integra Type R (RSX)
HP: 220
TQ:151
1/4: 14.3
Motor Code: k20a
RSX type S
HP: 200
TQ: 141
1/4: 15.0
Motor Code: K20a2
RSX (base)
HP: 160
TQ: 141
1/4: 16.2
Motor Code: k20a3
Civic Si
HP: 160
TQ: 141
1/4: 16.2
Motor code: k20a3
Hope this helped.Good luck.
Old Aug 2, 2003 | 05:32 AM
snipersi's Avatar
Almost right, the civic SI , althought the same engine as the base rsx, the SI has less torque to the tune of 132lbs
Old Aug 2, 2003 | 08:54 AM
JustaHonda's Avatar
Default Re: (snipersi)
Yeah, the base RSX has a dual runner intake like the ol GSR. Good for a little more grunt. The Civic has a typical intake.
Old Aug 2, 2003 | 09:04 AM
Big Si Guy's Avatar
If you run a 16.2 in a ep you can't drive or are at a horrible track.
Typically it's more like 15.6-15.8
Old Aug 2, 2003 | 09:12 AM
Default Re: (Big Si Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Si Guy &raquo;</TD></TR><TR><TD CLASS="quote">If you run a 16.2 in a ep you can't drive or are at a horrible track.
Typically it's more like 15.6-15.8</TD></TR></TABLE>
I have yet to see a ep run a 15.6-15.8 in stock trim here. The best anyone could do was a 16.2 in the 1/4. With hondata on the ep I have seen low 15.2-15.4.
So your comment on stock Si's running 15.6-15.8 is very rare, and I have yet to see one run that time.
And as for the comment on the Stock Si's having 132 tq, I stand corrected bro Good job . I can't be perfect all the time. hahahaa..
Old Aug 2, 2003 | 09:40 AM
00-ITR-373's Avatar
Default Re: (f1nal zeros)
Doesn't the EP have the dual runner intake as well? Just curious.
Old Aug 2, 2003 | 10:45 AM
redronin22's Avatar
It has the same intake as the rsx-s. the base model rsx gets a plastic unit.
Old Aug 2, 2003 | 11:53 AM
Todd00's Avatar
I said I don't want a title!
Default Re: DC5 and EP comparisons (Aiyoko Turbo)
The Si is eared a little shorter than the RSX and has balance shafts for some reason. It does indeed share the same intake manifold with the S so power output has the potential to be higher.
The Si is also shorter in length by over 7" than the RSX.
The RSX-S has the largest brakes and a 6-speed.
Old Aug 2, 2003 | 09:44 PM
Default Re: DC5 and EP comparisons (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">The Si is eared a little shorter than the RSX and has balance shafts for some reason. It does indeed share the same intake manifold with the S so power output has the potential to be higher.
The RSX-S has the largest brakes and a 6-speed.</TD></TR></TABLE>
And leather that will burn your *** and start cracking after a few months not to mention make your *** slide a bit when you enter a turn.
Old Aug 2, 2003 | 11:40 PM
Vtr's Avatar
Vtr
dude,
i like your picture.The rsx with the carbon hood and the lip.Post the pic pls...
eg_ruoner364
19
Jul 8, 2008 08:08 PM
DC2Hedi
Honda Civic (2006 - 2015)
Dec 19, 2007 03:58 PM
tomlinson619
Apr 12, 2006 12:54 PM
Djstorm100
Apr 20, 2004 07:18 PM
Art Vandeleigh
10
Aug 15, 2002 04:42 PM
