Need as much input asap, B16 EF Hatch no 4th sometimes, need for 1/4 tomarow...
Old Aug 1, 2003 | 03:38 PM
Nerologic's Avatar
Default Need as much input asap, B16 EF Hatch no 4th sometimes, need for 1/4 tomarow...
here's the deal, my car sometimes shifts into 4th, not all of the times. The linkage is cut and welded but i did not do it. The car used to shioft perfect as I was told. So anyone have any input? I need as much help as possible cuz im running the car in the 1/4 tomarow and im already late to work trying to get it to work so any help ideas pictures ANYTHING im desperate cuz i need a 1/4 to get a good run...THANKS everyone that responds, il be back later on tonight to check responses....
Old Aug 1, 2003 | 04:24 PM
Fobtions's Avatar
Default Re: Need as much input asap, B16 EF Hatch no 4th sometimes, need for 1/4 tomarow... (Nerologic)
make sure you have the clutch adjusted right, check oil in tranny,
Old Aug 1, 2003 | 10:56 PM
Nerologic's Avatar
i wish it was that, but i think the problem is in the linkage..anyone else??
Old Aug 1, 2003 | 10:57 PM
raene's Avatar
Default Re: (Nerologic)
If the linkage is cut and welded badly there's nothing you can do to fix it save cutting and rewelding it at a better angle.
Listen to the above guy - most tranny shifting problems are caused by badly adjusted clutches.
BTW let us know how the dragstrip goes
Old Aug 2, 2003 | 02:02 PM
Nerologic's Avatar
i just got home from the Track on my way to work im stoked my last run b4 i had to go was a 14.9 i was having 4th gear issues all day long but i hit 14.9 from 3rd to five...
Old Aug 3, 2003 | 11:25 AM
raene's Avatar
Very nice
Old Aug 6, 2003 | 08:45 PM
Bull_head360's Avatar
bump
Old Aug 6, 2003 | 11:11 PM
91HATCH's Avatar
Default Re: (Bull_head360)
i had the same problem...shifting was hard
i adjusted my clutch cable, and pedal..and it shifted much much smoother
Old Aug 10, 2003 | 12:42 AM
Nerologic's Avatar
i only get problems going into 4th..and i know the tranny is perfect cuz the guy b4 me swaped trannys, and his old and new tranny's are good the only thing i know is that it can be the linkage....
Old Aug 10, 2003 | 01:26 AM
Nerologic's Avatar
here is my timeslip...
Old Aug 10, 2003 | 10:23 AM
escocrx's Avatar
whens carlsbad open to drag? jus weekends?
i wanna run my crx there wit my new motor.
how much it cost?
Old Aug 10, 2003 | 12:23 PM
Nerologic's Avatar
25 bux its open every sat at 10am but they line up at like 11 just have ur bat tied down all lugs helmet and your good to go...
Old Aug 10, 2003 | 01:36 PM
raene's Avatar
You need a helmet for that? Strange!
Old Aug 11, 2003 | 09:22 PM
Nerologic's Avatar
im afraid so man....
slomotn
Jul 18, 2011 04:39 AM
sparcoboi77
Mar 19, 2008 11:28 PM
rsdracing
Apr 25, 2006 04:33 PM
astroxtc
Mar 5, 2006 11:15 AM
