Cam timing questions
Old Aug 1, 2003 | 11:21 AM
Relic1's Avatar
Default Cam timing questions
I installed a set of Skunk2 Cam Gears (both set to 0 till I can get some dyno time) and when I fired it up the exhaust was noticeably louder and it felt like I had a lot of mid/high power but the low end was slightly lacking.
After pulling the valve cover a few days later I discovered that I was a tooth off with both cams. (I had a paint can mishap before the swap so I “cleaned” off the paint in the lines on the crank pulley) Apparently I used the "red" mark instead of the "white" one to line up the cam timing with the new gears. stupid me. I moved it and set the ignition timing from 21 to 16 and it now runs at normal exhaust note and seems to have the normal power back.
This raises a major question in my mind. I was running both cams ~8degrees retarded and the engine ran freakin awesome above 3k and not really any real major issues below 3k except for a little less power than now.
I'm really confused....
Anyone have any idea why this is/was?
Or what exactly moving each cam does?
What does retarding/advancing the Intake cam do?
What does retarding/advancing the Exhaust cam do?
Why did running the cams that far off make the engine not run like total crap? Or even idle funky....
Old Aug 4, 2003 | 09:12 AM
Relic1's Avatar
Default Re: Cam timing questions (Relic1)
no one has any idea what changing the cam timing does?
Old Aug 4, 2003 | 09:43 AM
mmuller's Avatar
Mad Scientist
search knows.all you gotta do is type cam timming....
Old Aug 5, 2003 | 02:42 PM
PupaScoopa's Avatar
Default Re: Cam timing questions (mmuller)
Sport Compact Car did a write up on this last year I think (Suck/Squish/Bang/Blow series). Search their website if you don't find anything on here.
tinyscivic
Mar 9, 2010 09:03 PM
krysted9354
Dec 5, 2008 09:08 PM
Used2beAb16
Mar 26, 2006 10:32 AM
90AcuraIntegra04
Apr 6, 2005 10:35 PM
Lord Quaalard
Feb 11, 2003 07:15 AM
